MK808B coming with REALTEK WiFi/BT solution (ORIGINAL)
Got 180pcs and old firmwares are not compatible, now only the update_mk808b_v5.0_104j2103.img is compatible...Android TV Box direct from China. English & EspaƱol
Likewise...
Originally posted by danilocelic View PostWe need a rooted 1080p ROM for these new sticks (we have 100 sticks we need to image). Is there something we can do to facilitate getting updated ROMs created?
dave
Originally posted by harvdig View PostWe also need a rooted 1080p firmware, with or without wifi enabled. Have 50 sticks to setup.... pretty well stuck at this point.
dave
Works pretty well.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
mk808b, 1080p, lower clock speeds
Originally posted by Johnoo View PostWhat about a non oc'd version
I'm also interested in a non overclocked version, or even under clocked.... My application is essentially "digital signage", I need 1080p resolution, minimum power consumption, and rock solid stability. But not much else, e.g. I don't use wifi, bluetooth, netflix etc.
Thanks,
dave
Originally posted by harvdig View Postprahjisetr - Thanks! This does work for me. Although I had to tweak (via am display-density) the density to get my existing app to scale properly.
Thanks,
davePrahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Originally posted by [email protected] View PostTo unbrick this device is it procedure same, to conect pins 8 and 9 or it's different?Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
pins 8 and 9 work same as in original, I've done it, and it worked perfectly.
ROM that I used to unbrick is here: http://www.freaktab.com/showthread.p...B-Realtek-WiFi
Root access to Android 4.22 MK808B Rikomagic with RK903 Chip
Hello Friends
I have ths Image run: update_mk808b_v5.0_102j2101.img
My question is: we can roto Access activated ?
This Method work not: http://androtab.info/clockworkmod/rockchip/install/
i boot from CWM is ok and find from sd-Card this udate.zip
extract and install is ok. After reboot i check with Root checker normal and see
i have not root Access. SuperUser and super user fix is installed ok.
thanks for help.
There are currently 2521 users online. 2 members and 2519 guests.
