Their is a NEW Gotham XBMC 13.2 Beta HERE http://xbmc.org/download/#devbuild ...
NEW OFFICIAL/CUSTOM CS968 MTK T018 Android TV Multi-Media Super ROM 6/14/2014 {LibMedia.so, Pre-Rooted}}
The MobDro App Mass Multi-Media At Your Finger Tips
NEW Updated CS968 MTK T018 Google Android TV Multi-Media Super ROM, {Mobdro Now Built IN}
The MobDro App, the ultimate Mass Multi-Media TV Entertainment APP At Your Finger Tips, this app we don't talk about much ... The Mobdro app plays a very important part of the Ultra-Extra-Plus TV-Entertainment Package ...!
It's very hard to find this app, it's not in the Google Play Store, but it offer vast amounts of TV entertainment for the whole family ... Truly some people think the Mobdro app is just about on par with the XBMC as far as mass media TV entertainment is concern ...
Originally posted by sevx007 View Posti installed u rom from google comunity page ap6120 everything works but no wif .so i downloaded the t018 rom 4 times every time i use winrar to extract it it fails please help need rom
Originally posted by sevx007 View Postbasicly if i select 1080 movie in xbmc it plays well.
but how do i get the android desk top in 1080?
when i go to sreen specs it says 1280x672
Using a terminal emulator type: (use at your own risk after setting your TV to 1920 x 1080 x 60) ...
You can get the Terminal Emulator App Here https://play.google.com/store/apps/d...al.androidterm ...
Code:
su ↵
wm size 1920x1080 ↵
wm density 240 ↵
Reboot your Android TV box ...!
Please Note: make sure before you start your Android TV is set to 1080p, go to Settings> Display> Screen> HDMI Mode> 1920x1080p-60 check mark in blue, back out using the back key in the bottom taskbar ...
Originally posted by sevx007 View Postfrom u experiance does the device run fine once i do so or is it going to have issue?
also u did not respond to my question about the tv flicker on some tv's is there a fix for it?
New Mobdro App Now ChromeCast Enabled Or Cast Direct To Your Android TV Box
New Mobdro App Now ChromeCast Enabled, Or Cast Direct To
Your Android TV Box Via Android Smartphones/Tablets ...
Also This App Can Be Installed To You Android TV Box For Viewing Media Content On Your Big Screen TV HOT! HOT! HOT! ...
You Can Download The New Mobdro App HERE
http://mobdro.com ...
tv flicker
Originally posted by Tech1 View PostThe 1080p hack works fine, but I have never ever experienced the TV flicker issue
There are currently 2190 users online. 1 members and 2189 guests.
