Unfortunately Windows 8.1 users have problems getting the drivers installed and the flash tool working.
I don't have Windows 8 so cannot test why the drivers are a problem.
But.... here is the stock ROM in ZIP update format.
This is the Minix X8 BETA 004 - 7/1 ROM just released.
NOTE: THIS WILL ERASE YOUR DEVICE! So backup anything you want to keep!
Minix is not releasing ZIP updates only flash tool updates. The flash tool erases the box!
There is a reason for this.
Major updates it is much better to erase as you don't know what junk is left from previous ROM that can cause problems! As people saw on an update that did not erase, things were not right like a missing stock browser, etc.
__________________________________________________ _
DO NOT just put this download on the SDcard! Unzip the download and see the readme instructions!
Here are the download links.
ROM -> Minix X8-H - 07/01 BETA 004 Stock ROM in ZIP format - (466 megs)
Enjoy,
