I'm not sure where I read it, but one guy has fix his reboots in the way that he limit the SoC to 1000MHz... That's what I also will try (if I find a moment)... but step by step beginning at 1992...
Minix Neo X8/X8-H Stock BETA 4 in flashable ZIP format
I'm not sure where I read it, but one guy has fix his reboots in the way that he limit the SoC to 1000MHz... That's what I also will try (if I find a moment)... but step by step beginning at 1992...RK3288 Devices
- Overview BOX (LINK !)
Re: NEW - Minix Neo X8/X8-H Stock BETA 4 in flashable ZIP format
Originally posted by no_spam_for_me View Postforget it ...
with or without cpu_fix?
Sent From My LG G3 Using Tapatalk
Originally posted by Batfink32 View PostWith and without CPU fix. With CPU fix I get reboots every 5-10min. With stock kernel every hour or 2. This leads me to think its a heat problem.
(Somewhere I read something about using something like credit card to open the case... have a look at http://www.freaktab.com/showthread.p...e-Minix-Neo-X7)
As I wrote here
"The easiest way to freeze the system is to use 'PassMark PerformanceTest' (https://play.google.com/store/apps/d...mark.pt_mobile) and there at CPU do 1, 2 or 3 times the integer test and the system freezes...."RK3288 Devices
Originally posted by pmerritt View PostPersonally, I am on the original shipped rom, it's doing everything I need it to do except for Netflix. Netflix is no biggie though because my tv does netflix in HD.....SmartTV. My box never reboots, I don't have stuttering in xbmc, even in 1080p, after tweaking the advancedsettings.xml file. I am VERY happy with my X8-H!
which tweaks at advancedsettings.xml ?RK3288 Devices
I have to say - after having loads of trouble with MX player and the usual video players I was beginning to think I had bought another lemon.
BUT! After installing and running XBMC (which has never worked well on any other box I've had) I am amazed how good this box is. No problems at all as long as I use XBMC
Just stock rom with root. I have noticed that using XBMC invokes a very different CPU and codec profile - but maybe that's why it works great! Havent even edited advanced xml cos I read that this version will not use it anyway.
Originally posted by KEgg View PostGreat Rom Bob,
Is there a method to force a screen density change? I've done my usual build.prop alteration, but on reboot the screen stays at the default 240. Has Minix hard coded this in somehow so we unable to effect a change?
cheers
I will try the "am display-density xxx" (where xxx is the density value) in a terminal window but I doubt whether it will remain after a reboot.
There are currently 2119 users online. 2 members and 2117 guests.
