Easiest way to try Linux
Originally posted by linuxium View Post
CX-919 Working
Hi Linuxium,
Thanks so much for your hard work.
I have a CX-919 and just tried your "Rikomagic MK802IV New (AP6210)" image and it works a treat.
I was using a good quality sandisk SD card and it boots straight to Linux every time, is really fast and Wifi works perfectly.
A while ago I was playing around with Picuntu with my older iMito MX1 and although it worked, it took a while to load. I'm impressed how much faster a Quad core processor is compared with Dual Core.
Hm, thanks. i can run ur kernel on my mk802IV .... but i have Problems with MALI/UMP Driver. Mali gets loaded. Ump too. but if i try to load the disp_ump module i'll get an unknown Symbol error "disp_get_ump_secure_id".. any idea?
another question is:
i build the kernel with the rkwifi builtin.
Why do i have to load the module which is included in picuntu?
First of all, This is amazing, linuxium you are awesome.
I've tried dd-ing on my Ubuntu-box, didn't work but I think its a matter of my faulty sd-reader. With Disk imager it works 100% on a samsung class 10 -32 GB card. Works like a charme, except mali.
edit: I forgot to mention, its a Minix x7
I've copy-pasted your line from the first post and i also changed permissions to 666 e.g. 777, restarted lightdm but rendering is still software. This is what glmark2-es2 says:
Code:linuxium@LINUXIUMONE:~$ glmark2-es2 Error: eglInitialize() failed with error: 12291 Segmentation fault
Code:linuxium@LINUXIUMONE:~$ es2gears EGLUT: failed to initialize EGL display
Code:linuxium@LINUXIUMONE:~$ lsmod Module Size Used by mali_drm 5312 1 drm 138016 2 mali_drm mali 125540 0 ump 26364 3 mali fbcon 34343 71 font 4890 1 fbcon bitblit 3744 1 fbcon softcursor 888 1 bitblit wlan 476671 0
What to do?
edit2: got it. I missed a reboot and changes to dev are not permanent, so i added user linuxium to group video to prevent chmod 666 /dev/dri/card0
Code:sudo usermod -a -G video linuxium
edit3: i'tried to set color depth to 24bit in xorg.conf to test xbmc, but I only get some fancy colors, looks like a rainbow in a blizzard or so. maybe someone with more skill than me could write a postinstallation script for setting up mali and rise the color depth? I would really appreciate that.
@liltitiz: If mali works, you will get hardware accelerated 2d/3d but no hardware video-decompressing. This is about licensing issues for the video-codecs. But the Quadcores we are talking about are powerful enough to decode even 1080p in software. So XBMC's UI will be accelerated but no HW-decodingLast edited by itsme4sure; 25 August 2014, 20:39.
Which sd card compatiple full read/write speed
I used 8 gb sd card class 10 work very. but slow works for me. I want to buy new sd card for linuxium minix7 img. whic sd card full compability my minix mmc slot. Sandisk extreme pro 32 gb sdhc class 10 ush II 280mb/s or Sandisk extreme pro 32 gb sdhc class 10 ush I 96 mb/s
other issue how compile media driver
- I compiled and add tvheadend on minixbuntu. work perfectly. I need your help. I try to compile dvb media driver on minixbuntu. need build config (File not found: /lib/modules/3.0.36+/build/.config) file here is terminal log. if i compile desktop pc. linuxium which toolchain I need. indeed possiple and very easy compiling on minix ubuntu but some file missing minix buntu.
root@LINUXIUMONE:/home/linuxium# cd media_build
root@LINUXIUMONE:/home/linuxium/media_build# ./build
Checking if the needed tools for Ubuntu 12.04.4 LTS are available
Needed package dependencies are met.
* This script will download the latest tarball and build it*
* Assuming that your kernel is compatible with the latest *
* drivers. If not, you'll need to add some extra backports,*
* ./backports/<kernel> directory. *
* It will also update this tree to be sure that all compat *
* bits are there, to avoid compilation failures *
* All drivers and build system are under GPLv2 License *
* Firmware files are under the license terms found at: *
* http://www.linuxtv.org/downloads/firmware/ *
* Please abort in the next 5 secs if you don't agree with *
* the license *
Not aborted. It means that the licence was agreed. Proceeding...
Updating the building system
warning: expected SRV RR, found RR type 1
From git://linuxtv.org/media_build
* branch master -> FETCH_HEAD
Already up-to-date.
make: Entering directory `/home/linuxium/media_build/linux'
wget http://linuxtv.org/downloads/drivers...ST.tar.bz2.md5 -O linux-media.tar.bz2.md5.tmp
--2014-08-25 17:35:44-- http://linuxtv.org/downloads/drivers...ST.tar.bz2.md5
Resolving linuxtv.org (linuxtv.org)... 130.149.80.248
Connecting to linuxtv.org (linuxtv.org)|130.149.80.248|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 101 [application/x-bzip2]
Saving to: `linux-media.tar.bz2.md5.tmp'
100%[======================================>] 101 --.-K/s in 0s
2014-08-25 17:35:45 (2.54 MB/s) - `linux-media.tar.bz2.md5.tmp' saved [101/101]
make: Leaving directory `/home/linuxium/media_build/linux'
tar xfj linux-media.tar.bz2
rm -f .patches_applied .linked_dir .git_log.md5
* Downloading firmwares from linuxtv.org. *
dvb-fe-bcm3510-01.fw
dvb-fe-or51132-qam.fw
dvb-fe-or51132-vsb.fw
dvb-fe-or51211.fw
dvb-fe-xc5000-1.6.114.fw
dvb-ttpci-01.fw-261a
dvb-ttpci-01.fw-261b
dvb-ttpci-01.fw-261c
dvb-ttpci-01.fw-261d
dvb-ttpci-01.fw-261f
dvb-ttpci-01.fw-2622
dvb-usb-avertv-a800-02.fw
dvb-usb-bluebird-01.fw
dvb-usb-dib0700-1.20.fw
dvb-usb-dibusb-5.0.0.11.fw
dvb-usb-dibusb-6.0.0.8.fw
dvb-usb-dtt200u-01.fw
dvb-usb-terratec-h5-drxk.fw
dvb-usb-terratec-h7-az6007.fw
dvb-usb-terratec-h7-drxk.fw
dvb-usb-umt-010-02.fw
dvb-usb-vp702x-01.fw
dvb-usb-vp7045-01.fw
dvb-usb-wt220u-01.fw
dvb-usb-wt220u-02.fw
v4l-cx231xx-avcore-01.fw
v4l-cx23418-apu.fw
v4l-cx23418-cpu.fw
v4l-cx23418-dig.fw
v4l-cx23885-avcore-01.fw
v4l-cx23885-enc.fw
v4l-cx25840.fw
* Start building *
make -C /home/linuxium/media_build/v4l allyesconfig
make[1]: Entering directory `/home/linuxium/media_build/v4l'
make[2]: Entering directory `/home/linuxium/media_build/linux'
Applying patches for kernel 3.0.36+
patch -s -f -N -p1 -i ../backports/api_version.patch
patch -s -f -N -p1 -i ../backports/pr_fmt.patch
patch -s -f -N -p1 -i ../backports/drx39xxj.patch
patch -s -f -N -p1 -i ../backports/v3.11_dev_groups.patch
patch -s -f -N -p1 -i ../backports/v3.10_fw_driver_probe.patch
patch -s -f -N -p1 -i ../backports/v3.9_pfn_warning.patch
patch -s -f -N -p1 -i ../backports/v3.9_drxj_warnings.patch
patch -s -f -N -p1 -i ../backports/v3.8_config_of.patch
patch -s -f -N -p1 -i ../backports/v3.6_pci_error_handlers.patch
patch -s -f -N -p1 -i ../backports/v3.6_i2c_add_mux_adapter.patch
patch -s -f -N -p1 -i ../backports/v3.4_i2c_add_mux_adapter.patch
patch -s -f -N -p1 -i ../backports/v3.2_devnode_uses_mode_t.patch
patch -s -f -N -p1 -i ../backports/v3.2_alloc_ordered_workqueue.patch
patch -s -f -N -p1 -i ../backports/v3.1_no_export_h.patch
patch -s -f -N -p1 -i ../backports/v3.1_no_dma_buf_h.patch
patch -s -f -N -p1 -i ../backports/v3.1_no_pm_qos.patch
patch -s -f -N -p1 -i ../backports/no_atomic_include.patch
patch -s -f -N -p1 -i ../backports/v4l2-compat-timespec.patch
Patched drivers/media/dvb-core/dvbdev.c
Patched drivers/media/v4l2-core/v4l2-dev.c
Patched drivers/media/rc/rc-main.c
make[2]: Leaving directory `/home/linuxium/media_build/linux'
./scripts/make_kconfig.pl /lib/modules/3.0.36+/build /lib/modules/3.0.36+/build 1
Preparing to compile for kernel version 3.0.36
File not found: /lib/modules/3.0.36+/build/.config at ./scripts/make_kconfig.pl line 33, <IN> line 4.
make[1]: *** [allyesconfig] Error 2
make[1]: Leaving directory `/home/linuxium/media_build/v4l'
make: *** [allyesconfig] Error 2
can't select all drivers at ./build line 490.
Originally posted by taki View PostI used 8 gb sd card class 10 work very. but slow works for me. I want to buy new sd card for linuxium minix7 img. whic sd card full compability my minix mmc slot. Sandisk extreme pro 32 gb sdhc class 10 ush II 280mb/s or Sandisk extreme pro 32 gb sdhc class 10 ush I 96 mb/s
USED PROGRAM H2testw v1.4
TOSHIBA CLAS 4 8GB
Warning: Only 300 of 7403 MByte tested.
Test finished without errors.
You can now delete the test files *.h2w or verify them again.
Writing speed: 3.02 MByte/s
Reading speed: 15.0 MByte/s
SANDISK CLAS 10 32 GB
Warning: Only 300 of 30428 MByte tested.
Writing speed: 7.72 MByte/s
Reading speed: 30.2 MByte/s
all dvb modul rk3188 ubuntu 12.04 linuxium
tested that is work
you can use dvb stick (dvbt/s/c) only find your modul later load insmod
stock kernel mdoules
V4L-DVB Device Drivers
s2-liplianin-v39
Originally posted by jpearn View PostHi,
I have this working on my old MK809, however my audio stopped working after a couple of reboots ? I am guessing this is an Alsa mixer issue (not dug into it too deep yet) . . . ?
Also how do I go about installing this to NAND, as I think the older NAND images are not up to date with kernel etc. ?
Thanks !
I M ALSO FACING SAME PROBLEM. DO YOU FOUND ANY SOLUTION? IF YES PLEASE LET ME KNOW.
THANKS
Change of wlan0 mac address
Thanks for the awesome work!
BTW, is there any way to change the mac address of wlan0 on the level of image files such as replacing or modifying a parameter file? I am wondering if it is hard-coded at the time of kernel compile. I am running linux on the two different different devices, UGOOS UM2 and Tronsmart MK908II, and allocate fixed ip addresses based on their MAC addresses from a router. Two devices have the same MAC address for wlan0. I found a way spoofing ip in linux, but want to know if there is a simple way as mentioned above.Last edited by xpanda; 22 September 2014, 18:09.
There are currently 2441 users online. 1 members and 2440 guests.
