How to reflash the tablet?
1. Download the firmware
Password is geekbuying.com
2. Run flash tool “the Flash_tool.exe”
3. Choose “Scatter” file.
4. At this point, you need to remove the battery from your device and connect the device to a USB 2.0 port on your PC (USB 3.0 is not supported). You should start hearing the “dings” in Windows to signify that it detects your device.
5. Click the Download button on the Flash Tool.
6. If your device is connected properly, you will see the percentage bar change colors and start running. The one to watch is the yellow bar that goes from 0-100% indicating that the ROM is being flashed.
7. You will then get a window with a green circle, indicating that the flash is complete.
8. When the flashing process is done, disconnect the USB cable and replace the battery in your device and turn on the device. Your device will then boot into the newly installed ROM.
Highlight of the tablet:
- Android 4.2 OS.
- 7 inch 1024*600 IPS capacitive touch screen.
- MTK8382 Quad Core 1.3GHz.
- 1GB DDR3 RAM and 8GB NAND FLASH ROM.
- Support Bluetooth/GPS/3G/FM function.
- Support GSM 850/900/1800/1900, WCDMA 2100.
- Front 0.3MP + Rear 2.0MP camera with flash.
B.regards!
GEEKBUYING
