My TV box came yesterday and well, have to say I'm quite disappointed with it. According to the specs, it has to stream perfectly 720p, and well, it doesn't 100%. Apart from that, the pre-installed XBMC (beyond) had a lot of problems: black screen, missing icons, freezings and shutdowns.
Curious thing is, the seller 'sells' the TV box as a K version, but I've recieved a version with BT, then, it's leaves us two scenarios: 1- Seller mistake or 2- it's a K modded version with a BT built-in. Here's the link: http://www.aliexpress.com/item/MK888...119494403.html
In that case, is there any ROM out there that improves performance in 720p playback? Here are the photos of the PCB, so you can help me identifying if it's a real 'K', a modded one or a genuine 'T'.
Thanks in advance!
