Pipo M7 Pro RileyROM 3.3 KitKat
    This ROM is based on official Pipo factory firmware dated 6/18/14.
    There's no change log, but I've been running it and everything seems to work well.
    This ROM is:
    Rooted
    Debloated
    Init.d/Busybox support
    User app space options from 1 to 12gb (4gb default)
    Auto Install available (as with my other ROM's)
    TWRP Recovery by Abdul_pt...installed after first boot
    Google Play Store fixes
    All of the typical RileyROM features
    Reboot app by Petrus
    Flash Tool by Finless
    Boot animation by me
    Download
    Enjoy!!!!!!!!!
    Don't forget to donate to support future RileyROM's here on Freaktab...that really helps me stay up to date on the latest devices.
    Randy
    Thank you again for your great work Randy!
    Hopefully this rom along with the new kernel #88 dated June 18, 2014 will be better than the previous roms.
    It's nice that you have included the rom version in the bootanimation.
    Proud M7Pro owner and Freaktab fan
      I have an issue: no sound at all.
        having the same issue. I think the problem is in the new kernel. I flashed the older kernel from 3.2, tab have sound again.
          Did you guys notice any change or performance increase in this 3.3 build compared to 3.0 ?
          I want some feedbacks before I flash
            I'm running 3.3 on mine and sound works. I watched a movie last night with no problems.
            Randy
              I think riley's Pipo tablet is an excepcional one, never a problem, it's made of steel 😉
                I return using 2.8.1 again, at least it sounds 😁
                  I have flashed from 3.3 to 3.2 kernels back and forth but same results, no sound when on 3.3 kernel
                    Really...that's true...this M7 Pro is a great tablet!!!!
                    Randy
                      That's it Randy, your unit is a great tablet, I can't say the same of my unit, always with freezings and shutdowns with every ROM I tested, surely the chinese worker mounting mine wasn't in his best moment. Greetings.
                        I have a question plz but I don't know if it's related to the rom or not.
                        Anyway, is there a way to get the hdmi to output at 1080p 24hz ? there's only 50hz and 60hz.
                          Have you flashed 3.3? Do you have sound on your tab?
                            I'm really sorry, I thought I'm on the M9Pro thread
                              I have the same problem. Did you find a solution?
