.gif)
Pipo M7 Pro RileyROM 3.3 KitKat
Originally posted by demarcha View PostAmshpitz, at this moment 2.8.1 is the more stable for my tablet,but get problems past two or three weeks from flashing. (Sorry about my bad english and the fkd spanish corrector)
That's right 2.8.1 is much more stable.
I had installed 2.7 a few months and nothing happened, suddenly it start to freeze
Thanks for testing. I just offer up the alternatives to let you guys decide which is best for your particular device. Just like medicine...this is an art....not a science.
btw...my tablet rocks on this ROM. So results may vary.Randy
There seems to be a hardware variation to this tablet that for some unlucky ones...the sound doesn't work. I suggest flashing the 3.2 kernel if you have this problem.Randy
Btw...my tablet has the same problem. But sound does work through the headphones.Randy
Originally posted by MFinchy View PostUps,
RR 3.3 works very well for me. Very smooth, no freezes..... but no sound as well
I use may M7 mostly without sound, so I didn't recognized this problem
I hope that there will be a fix.
@cshock2010: Which OC kernels are you using?
Here are my kernels from RR3.2 and 3.3
M7Pro Modified Kernels
for RileyRom 3.3 [KK]
Kernels_M7Pro_RR33.....zip
for RileyRom 3.2 [KK]
Kernels_M7Pro_RR32.....zip
Originally posted by MFinchy View PostThanks cshock2010,
I'm now using kernel_M7Pro32_cpu1704-low_gpu600_ddr720 and it seems so far stable and fast.
Sound works as usual.
What are the differences between the two kernels?
Hoping for a fixed kernel on the next release.Proud M7Pro owner and Freaktab fan
It think the best combination at the moment is the 3.3 ROM with the 3.2 kernel.Randy
Yes there is a solution.
It involves getting the Launcher3.apk from the 3.2 ROM and copying it into the 3.3 ROM.
I will try to make a fix, today.
How about v3.3.1 with the 3.2 kernel and the launcher fix?Randy
There are currently 1993 users online. 0 members and 1993 guests.
