minix x7 + hdd
@flumpster ive got it to connect through flashfxp thankks for that. but heres another problem is this
Custom Folder : When the popup appears browse to mnt/usb_storage/USB_DISK0/(name of your hard disk)/ and then click select to accept that folder. This will be where your ftp client on PC will connect to by default.
my hd didn't show its working because i have music on it. and when i looked at flash there was only sdcard0 so do i need to mount it ive turned it on/of and the x7 sees it but its not listed thanks.plus there is nothing in sdcard0.
Originally posted by seagate1 View Post@flumpster ive got it to connect through flashfxp thankks for that. but heres another problem is this
my hd didn't show its working because i have music on it. and when i looked at flash there was only sdcard0 so do i need to mount it ive turned it on/of and the x7 sees it but its not listed thanks.plus there is nothing in sdcard0.To Infinity and Beyond.... XBMC
thanks again thats what ill do later.its just the same lay out as the solo2 when opened in flash, ect/bin media folders and so on.i can find my internal hd on the solo2 by looking in media fodler and its seagate 1tb so i will look again plus thanks for the ftp instructions, i find it a lot easier transferring files. ive been doing it that way for 20 years with stb.
There are currently 2449 users online. 0 members and 2449 guests.
