It's the model with a hard fastened heatsink that covers the NAND chip but pins are accessible. I have tried shorting pins 8-9 but still nothing, it won't leave maskmode (blue square) that won't let it get past "download IDB fail". What can be done about this?
MK908 v3 keeps reverting back to maskrom mode no matter what
I have tried severally to get it out of maskmode and it keeps reverting back. No rom I try to flash it with makes it past "download IDB fail" while in mask mode. It's on layer 3-1-3. No matter what port or computer it's plugged to the result are all the same. Tried changing cables to much shorter higher quality, the results remain the same.
It's the model with a hard fastened heatsink that covers the NAND chip but pins are accessible. I have tried shorting pins 8-9 but still nothing, it won't leave maskmode (blue square) that won't let it get past "download IDB fail". What can be done about this?Tags: None
Originally posted by akismal View Postthe same happened to me (pins 8 and 9 stayed shorted), i fixed it with a small pin that i separated the pin 8 and 9. Be careful pins are sensitive
Originally posted by Dendrobite View PostI have cleared the space between even with isopropyl alcohol but still doesn't change anything.The funny thing is if I struggle several times to short those pins, at some random interval it is changing state to green and failing at "reset device fail". Plugging it back reverts back to maskrom mode. The pins 8 and 9 have nothing in between them right now but still reverts to maskrom mode. What next?
There are currently 2283 users online. 3 members and 2280 guests.
