I have issues with my tv box I have bought from aliexpress
I have received the TV box but the box was not working properly. So I contacted the seller and he suggested to do a firmware upgrade. He sent me this link.
I have done everything as per instructions, I could connect the box to the computer, the only mistake I have done was to click on 'upgrade' instead of restore... a bit confusing I should say...
Anyway after the 'upgrade' there was no error message. But right after that the power button led turned red.
After his my box is not recognised by the computer anymore, I cannot install the driver at all.
Any suggestions?
