Boot problem with my TV Box
That's not what I told you to do ... you never remove the OTG usb connection while you are installing the ROM ...!
Are you getting the connection sound from your computer, while the OTG usb is connected to your computer, that's the key ...
If you cannot follow my instructions, then their is nothing I can do for you ...
You will always get the Android guy, simply because you don't have a connection to your PC ... Do you have the correct drivers installed on your PC ...?
There are currently 4179 users online. 1 members and 4178 guests.
