Pipo M9 KitKat ROM for those with 1nand chip who gets bricked by official fw
Re: Pipo M9 KitKat ROM for those with 1nand chip who gets bricked by official fw
Originally posted by chrs11 View PostThanks i
will wait
I tried to flash it but failed in doing so. I have one of the very first Pipo M9 Max tablets so there's only a few (old pcb) firmwares I can use. This pretty much sucks.
Anyway, this version almost seemed to work because my pc recognised it as normal but there's no display except a black screen (display is on, it emits light). So is there only a problem with the display being not supported or is there more? Same story for RileyRom 2.4 and 2.5 btw.
Would love to finally be sort of up to date, instead of having only 2 firmwareupdates since I bought it.
Wifi doesn't work
Hi dnkn,
I flashed the ROM on my tablet several times (with the RK3188Loader(L)_V1.24.bin selected and without it), and every time I got the WiFi not able to turn on. It stays on "Turning WiFi on.." . I manged to turn it on once after multiple reboots but on the next reboot it stuck on the "Turning WiFi on.." again.
I even reset to factory settings. Nothing helps. Before this ROM I'd been using Riley 1.5.
Before flashing your ROM I made sure that my tablet only has one NAND chip. I opened it and there is one 16GB chip installed.
Please, help me to sort it out.
Thank you!
Originally posted by dnkn View PostWell, this ROM is fully stock in terms of kernel and system partition, so if WiFi does not work then it would not work on stock ROM, I suspect hardware malfunction. Try to flash 1.5 back, will it work there? And may be you've touched something while assembling the unit?
still waiting for my m9 to be returned after RMA. As it turns out, it had to be sent all the way to China and it took them three weeks to figure as much... starting to sound like BS if you ask me...
anyways, is there a bulletproof method to ascertain whether my tab has one or two nand chips without opening the case?
Great work, dnkn!!! Kudos!!
Yes, there is. Look in Riley ROM 2.6 thread, some app is able to show whether you may flash official fw or this one. Anyway I would recommend to flash my updated system.img even with official fw, it solves some problems like wrong gapps in official fw and some apps showing "incompatible with your device". If on official fw just flash that system.img only after flashing official fw.
WiFi issues... and reports
Hi y'all. Let me tell my experice so far..
1st flash... Worked fine, but flashed stock.
2nd flashed system.imG only... Got stuck on the 4 penguins.
3rd time flashed all over including bootloader selected and the system.IMG fixed...
At this point I got some weird actions... Xbmc would not start 1st time... Worked on 2nd..
WiFi disconnects and stay disconected after standby. Have to turn of and on the wifi for it to connect again.
Battery life is the same as the latest pipo ROM. 4-5 hours and back to the wall...
KK is much better that JB in my opinion. All video softwares worked without any problems... Videomix, Netflix, xbmc and so on. MX had to run a video on my SD card first for it to work URL videos... Weird again..
My veredict , works OK not many glitches other than those... Wifi will get old and get used to it... Or hope for some fix...
If you wish I cold be a tester of any updates. Already brought it from the dead 100 times... Rk is almost unbrickable, and I did some real stupid shit with it...
Hope for improvements keep the good work man!
There are currently 2027 users online. 4 members and 2023 guests.
