[ROM DOWNLOAD] STOCK FIRMWARE FOR MXIII AMLOGIC S802 QUAD CORE TV BOX
Bare with me please .. I was trying to do all that on my wifes pc and a its freakin slow .. B I even had to install winrar .. And c its even slower tryin to do two things at once .. But i will figure out imgflashing .. I may have gotten lucky with the sd card this time cause it booted in recovery .. You think it will be doing it again ? The whole hanging at mbox thing ? Since i didnt do the img flash?
Sent from my LG-V500
Re: [ROM DOWNLOAD] STOCK FIRMWARE FOR MXIII AMLOGIC S802 QUAD CORE TV BOX
Originally posted by infamouskid View Postdid you try turning on wifi in settings?
Sent from my GT-I9505 using Tapatalk
i'm using latest one in playstore. no problems.
but i found version 3.7.2 and 3.7.1 to be the most stable.
Originally posted by dlangejc View PostDoes anyone else have issues on Netflix play back that's jerky on this device?
Not the best I have seen hope it can be corrected.
Sent from my iPad using Tapatalk
WiFI Issues
My MXIII 1GB with Realtek RTL8188 Flashed with 108K4 is locking my download speed to only 0.67 to 0.68 mbps, when on ethernet goes to my normal 25 mbps. Upload remains same on both (wifi and ethernet) at 2 mbps on speed tests. Has anyone had this issue and is there a fix. I could settle for wired option but it would be nice to have it running wifi more than 5 mbps at least. My router is currently just 2 ft away from the unit.
Originally posted by egx2 View PostMy MXIII 1GB with Realtek RTL8188 Flashed with 108K4 is locking my download speed to only 0.67 to 0.68 mbps, when on ethernet goes to my normal 25 mbps. Upload remains same on both (wifi and ethernet) at 2 mbps on speed tests. Has anyone had this issue and is there a fix. I could settle for wired option but it would be nice to have it running wifi more than 5 mbps at least. My router is currently just 2 ft away from the unit.
maybe you can also use it at WiFi...
(only an idea)
EDIT:
"My router is currently just 2 ft away from the unit."
This could also be a problem!RK3288 Devices
- Overview BOX (LINK !)
netxeon MXIII V.3 S802/A P6181/1G/8G
After one week of use box went dead. Flashed few times M82_107k4_1gddr_rtl8188 and M82_108k4_1gddr_rtl8188 but it did not work. After flashing FW i have Google TV screen then it get black. Disconnect box from power then i get it all the way to work for only one time. After that black screen again.
SD update doesn't work too. Got reply: can't find /dev/block/mmcblk01
Any help?
Thank you
There are currently 2428 users online. 0 members and 2428 guests.
