Thank you
Android 4.4.2 KitKat ROM for Q7 EKB311B (PCB XT-Q7-V10 2013-12-05)
Fixed ir remote with my new ROM/kernel.
Red LED light - You will have to make 100's of kernels for every different device to turn light blue, which is not worth it. Also difficult to implement
Originally posted by hedehede81 View PostHi mo123, I use your kernel with my Q7 Stock ROM and 1080p, wifi, bluetooth and ethernet works. Yesterday I tried IR remote and it didnt work, would you be able to send the updated kernel with working IR Remote? Many thanks.
Originally posted by mo123 View PostIf anyone post above info required......
I did what you said:
-here in the archive files dmesg and other captured on my box with stock and your kernel
https://yadi.sk/d/Okt7Zf1ebfkXK
-also I checked the sound through the AVout after flash kernel for MT5931 (I tried the version of the kernel, called "HD" for TV-boxes).
Yes, with this engine sound with AV output works well.
Thank you !!!
hi all , i have XT-Q7-V10 device , i update the device with firmware 4.4.2 with therk tools you write here and it works great , but after 1 hour of working the device stop working
first i think i have a problem with electricity , but when i see all the other device work i understand that i have problem with the tv box
when i connect the device to the electricity i see for 2 second a red light and then the light gone
try to push the on/off button but no action
please advise me what to do , maybe the problem is with the upgrade that i did but it works with good wifi reception
please help !!!
Originally posted by dim View PostHi all.
New official firmware for EKB311B - Android 4.4.2 KitKat.
[ATTACH=CONFIG]7229[/ATTACH]
Label on box:
Model: EKB311B
Quad Core Smart TV BOX
Factory: ENY Tecnology Co., LTD
Board specs:
CPU: RK3188RAM: Samsung K4B4G1646Q-HYKO 2GB
Audio: Rockchip RK1000-SPMU: uP6636Q PGU43E
HDMI: ITE IT66121FN
Wifi: Realtek RTL8188EIV
Bluetooth: Mediatek MT6622N
Skhynix H27UCG8T2ATR chip
Engraved onto board:
XT-Q7-V10
2013-12-05
Link:
http://pan.baidu.com/s/1dDzRw6d
Hi, I have a PC Android like the Q7 of this discussion, with the same case, but I have a problem with the case: I removed the 4 screws at the base of the 'Android box (those under the rubber feet) but the case are notIt opens in two and remains firmly attacked
Originally posted by Kazanovapt View Postcs918 doesnt recognize in windows
i have a problem with my cs918, windows 8 doesnt recognize, i downloaded the batch tool 1.7 and still with the driver and windows still doesn't recognize it, can someone help me
There are currently 1987 users online. 3 members and 1984 guests.
