Eric
New firmware Acemax M8 22/07/2014
EricLooking for developers
Originally posted by Finless View PostKitkat SU binary must be run as a Daemon. You cannot just copy the files. Use my S89 EZ root ZIP and it should root it just fine.
Update:
Yes that must be the one according to following thread name:
Originally posted by Marton4 View PostHi Bob, You mean this file: s89_root_update.zip?
Update:
http://www.freaktab.com/showthread.p...oot-ZIP-update
both same file
JustMeBugs are Sons of Glitches!
JustMe
Originally posted by TMx View Post... Overheating?and at xbmc I recognize CPU usage much less then 20% (at 4 cores) at s802 devices...
RK3288 Devices
- Overview BOX (LINK !)
Originally posted by bajann View Postsomething strange with all s802 ;dont change skin in xbmcplz test xbmc only with originali
I do hope they fix the problems of this fw and I update my fw...
New to the M8.
Will after i received my M8 if will not hold the Ethernet connection and have turn it on manually all the time and keeps crashing and the only way you can turn it off is to unplug the power cabole out the back. tried most things any idea?
Installed the new fw from here no xbmc so i installed gotham 13.2 sound no video Help lol
Cheers
Paul
Kerel Versons
3.10.33
ubunttv@ubuntt1886
fri jun13 12.42.15 cst 2014
Buikd No Kot48h 2014 00.16 key testLast edited by doingok43; 08 August 2014, 17:21.
Originally posted by warlock09 View PostAnybody using this firmware having issues , for xbmc especially 1080p H.264 playback..video freeze audio still going on..interlacing problem...can u pls..share your experience..whatever version of xbmc your using..thanks....
There are currently 4268 users online. 0 members and 4268 guests.
