As title says I have bought a relatively unknown Rockchip Android Smart-TV stick - Andersson ADS2.1 - as far as I know - only marketed in Sweden.
I am well aware of this probably being one of the already known chinese types out there - only rebranded for this store and for the Swedish Market.
I was hoping someone around here would be able to help me gather some info on it? Whether I can update it with better / newer firmware - or flash any type of ROM - CM11 or something such...
I HAVE managed to ROOT it using something chinese. If needed I'll be happy to supply a link for it.
Just the way it is right now - I have found no way of installing a working advanced Power Menu, and not even ClockworkMod.
Also the GUI is almost unbearably unpractical. Programs don't shut down unless I kill them in Process Killer, there is no SOFT option of restarting the stick, only option is holding down power on the device itself for 10 seconds.
Here are the specifications as found on the webpage.
Specifikationer:
Chipset: Rockchip RK3066
CPU: AMR Cortex A9 Dual core 1.6 GHz
GPU: Mali-400MP Quad core
RAM: 1 GB DDR3
Flash memory: 8 GB
Memory card: Micro SD up to 32 GB
WiFi: 802.11 b/g/n
Android version: 4.2 .1Jelly Bean
Bluetooth: 2.1
USB port: 2.0 and Micro USB host
Power: 5V USB (500mA-2A)
It also has a bluetooth controlled remote to control it.
This is the link to where I can actually purchase it
would be grateful for any info and tips.
-0.jpg)
