N101-II ROM compatibility
    OK Tuen supplied me with a dump of the new N101-II ROM.
    I can tell you kernel is NOT compatible with the N101 model. However system.img from the N101-II will boot using N101 kernel.
    So we may have some kind of update using system.img from the N101-II but I have to spend the time seeing what works , whats fixed, etc.
    One thing I see already using the new N101-II system.img is there are soft volume buttons on the bottom status bar and they do work with the N101 and kernel 26.
    More to play with
      N101 - II Information screen
      Model Number
      N101 Dual Core 2
      No sense in stating the kernel version since it's #26
      Firmware Version
      (MC_CN@20120724)_V404.11_TL12
      Build Number
      rx30_ics_v2.23.00
      rc30sdk-eng 4.0.4 IMM76D eng.jp.20120724.110525 test-keys
        Tuen supplied you?
          Originally posted by Piers View Post
          Tuen supplied you?
          Yes he gave me the download link for it. He did not say where it came from. I hope I am not getting him in trouble or anything. He did not tell me I could not say anything only to not share the dump at this time.
            it's fine, i did the rom dump from my n101 ii just for you and tuen, i posted it on VD in the dev forum for you both.
              OH sorry... He PM'ed me the link. I did not look in the Dev forum after that. I was at work so wasnt able to poke around much.
              OK so THANKS Piers!
              So far the -2 system works great with kernel 26. So I will probably build yet another ROM for n101-1's with it.
              Too bad the kernel is not compatible. The -2 kernel totally bricks the -1's
                ah i see. i thought it might be useful for the old series. so far i havent seen any issues with the firmware that came with the tab and im sure when more people own it someone might make a custom rom
                  -2 system.img also appears to have all needed fixes to give the full google play store. Again this is the -2 system IMG being used with -1 kernel #26. So at least when I make a ROM from this for -1 folks, thats one less thing I have to fix
                  Wifi time out with slow DHCP hotspots is not fixed! Same problem as all the other ROMs.
                  More stuff to test.
                    I dont have to own it to make a custom ROM for the -2
                    I have made more ROMs for tablets I dont have than ROMs for the ones I do
                    So if you guys are OK since you supplied the dump, I will do a ROM with the same features as in my 1.5a or 1.6. In fact I can probably have it this week real job permitting!
                      yep that would be great, although i ask that you dont use the ft boot animation.
                        The bootanimation? That's easily removed. Just delete /system/media/bootanimation.zip
                          Hallo,
                          sorry i cant speak english. Ich habe ein n101 - 2 und seit 2 tagen startet es nicht mehr.
                          Ich wollte es mit dieser
                          Stock ROM 0719 Kernel#26 - Whats coming with the August Tablets
                          wiederherstellen aberes geht nicht. dabei habe ich nach der Anleitung auch den nand speicher gelöscht.
                          Jetzt habe ich ein leeres Tablet ohne os und finde keine custom rom im internet.
                          Ich wäre sehr dankbar wenn ihr mir ein Backup der firmware für die neuen n101-2 zur verfügung stellen könntet, das das gerät endlich läuft.
                          Am besten mit einer kleinen anleitung weil ich noch nicht so viel ahnung von android habe.
                          vielen dank schonmal
                          blackpet
                            Originally posted by blackpet View Post
                            Hallo,
                            blackpet
                            Hallo,
                            while I'm following the instructions and deleted the nand memory.
                            Now I have a blank tablet in the internet without os and can not find a custom rom.
                            I would be very grateful if you give me a backup of the firmware for the new n101-2 could provide for disposal, which finally gets the runs.
                            Preferably with a little instruction because I have not so much unaware of android.
                            Many thanks
                              Hallo,
                              blackpet
                              Translation
                              Hello,
                              sry, but I can't speak english. I've got a n101-II and it doesn't start up/boot since 2 days.
                              I tried to recover with SEE LINK above, but it didn't work, although I've deleted nand memory,
                              as its described in instructions.
                              Now I've a blank tablet and I can't find a custom ROM in the internet.
                              I would be so grateful if you could supply me the stock ROM within my tab could
                              work as it should.
                              For best, with a little ReadMe on how to flash.
                              Thx
                              Gesendet von meinem AN8BG3 mit Tapatalk 2
