MK808B V5 Realtek 1080P Working Netflix Prahjister 1.0 Beta
808 B with realtek
Originally posted by prahjister View Post
I tried your [ROM] Prahjister ROM 1.0 MK808B Realtek WiFi
and this one > You tube is working fine. I do not see any issues.
720p version keeps the device cool,
I also tried1080- I could feel the board heat up a little, I am using a cooling fan, no issues eitherway.
**** Thanks for all your hard work ****
Please inform if you have a solution for Google Play Movies.
Originally posted by jo010118 View PostI tried your [ROM] Prahjister ROM 1.0 MK808B Realtek WiFi
Please inform if you have a solution for Google Play Movies.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Originally posted by jo010118 View PostIf you can't that's ok. I could not find any other issues with this, it is a good stable ROM.
Thanks again!Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Originally posted by prahjister View PostDecompress and Flash
To get your device in flash mode use a pin in the hole opposite the blue light...while holding plug in usb to pc. When you see found rkandroid you can let go.
Link to Drivers
If you want 720 let me know and I will put some files up with instructions on how to do it.
When flashing 1080
KitKat Launcher
Netflix Working 1750
1080 works on everything i tried
Init.d working with scripts in /system/etc/init.d
No need for setcpu look at cpu script in init.d
Replaced browser...sites still zoom the first time you go to them while loading but after that they dont zoom
Bootanimation if you want to change place your bootanimation in /system/media/
Removed crap apps.
SPMC is in /system/usr you have to install. Navigate to folder to install. Remember to go to settings and security and check unknown sources before installing. The latest SPMC is the only one that will work.
Updated all apps i could...kitkat launcher is going to look and act stupid until you update search in the play store.
Warning....this is oc'd.....Flash at your own risk...You must have a good power supply and usb cable...I use an Ipad charger and a usb cable I made. I also use a fan.
https://drive.google.com/file/d/0B3T...it?usp=sharing
Any requests or issues let me know and i will try to fix/add for Final rom..More to come.
i just wanted to say thank you for your hard work. this looks great on my mk808b
Originally posted by postaltaco View Posti just wanted to say thank you for your hard work. this looks great on my mk808bPrahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Originally posted by prahjister View PostYou should flash 1.0....its cleaned up more. Non Beta
I was able to get 1.0 working on the device. However, when I flashed the 1.2 it would flash ok but then after it was flashed and tried to reboot it would only go to a black screen. The blue light would stay on for a few minutes but then that would shut off too.
I posted this on another thread but maybe this is the correct place, is there anyway to get full 1080p working instead of scaled 720?
Thanks again and this is really an awesome piece of software
Picuntu and MK808B V5
I was wondering if anyone was able to use this ROM and flash a Linux kernel on the recovery partition (procedure described here: http://www.freaktab.com/showthread.p...MK808b-SUCCESS!! ) of a MK808B V5 with RTL wifi chipset. I have successfully flashed prahjister's ROM on mine and can use it fine with Android but I would like to try Picuntu on it. However, when I flash the kernel onto recovery and reboot to recovery, I get a blank screen on boot. The little blue light does turn on however so I suspect it probably boots but somehow the HDMI driver does not work as expected.
Thanks for any light anyone can provide.
There are currently 2136 users online. 3 members and 2133 guests.
