My Modded M8
My Modded M8
Bugs are Sons of Glitches!
JustMeTags: None
Originally posted by TMx View PostWhere Wifi antenna my friend
on order the one i wanted i get it next week also still some custom moulding to do if i get motivated fibreglass and
JustMeBugs are Sons of Glitches!
JustMe
Guest
Guest
I had a spare old beat Wi-Fi antenna, couple of dollars new on ****, and hooked it up last Monday to the PCB. My speed tests for the Wi-Fi now is the same as cable Ethernet.
Originally posted by washere View PostI had a spare old beat Wi-Fi antenna, couple of dollars new on ****, and hooked it up last Monday to the PCB. My speed tests for the Wi-Fi now is the same as cable Ethernet.
washere well done - yes you will get more stable speeds I should have my 9dbi antenna on tuesday.
also look out for my furthur mod to come lol
JustMe
Pre amtenna wifi speed = ?
Post amtenna wifi speed = ?
What DBi antenna =?
How farr is your router from m8 = ?
What Speed is your lan and what speed you achived wifi before and after mod =?
Cheer
JustMe
Standard box doing 30 on wifi , 80mbps on Ethernet here...
Guest
the antenna is ripped from an old router i binned 3 years ago, looks pretty much like $2 **** ones
router is about 5 meters away
before my wifi was about 7mbs
after it matches ethernet cable about 15mbs
m8 antenna cable inside has none of the 3 type jacks, badly soldered, try to get separate connections for 2 wires
i ran a foot of flat aerial cable through bottom vents to aid reception
i made different types of very effective dish & telescopic wifi boosters in my last place, you can make a simple bent foil panel through router antenna
Guest
[IMG]http://luckyretail.com/Uploadfile/****/0667/PJWKA-0667.jpg[/IMG]
$2.50 delivered
http://www.****.com/sch/i.html?LH_BIN=1&_from=R40%7CR40&_sacat=0&_sop=15&_ nkw=WiFi+antenna&_pgn=5&_skc=200&rt=ncLast edited by Guest; 10 August 2014, 10:28.
Guest
Since our friend JustMe did not share how to enable OTG on the PCB, can anyone else in touch with them ask suppliers and inform members here how to do it?
There are currently 1625 users online. 0 members and 1625 guests.
