TWRP for Square M8 by Abdul Finished & Working: Can Backup Your Whole System
So flashed TWRP and rebooted into Recovery no problem took a NAND backup to External SD-Card rebooted into Android System. Now the trouble starts Flashed Finless 1.8 Rom and it failed so rebooted got Finless 1.8 Splash Logo and it went straight back to TWRP Recovery, so tried Fixing Permissions nothing reverted back to TWRP NAND Backup earlier successfully restored though every time i reboot of Power Off and start up it goes straight to TWRP Recovery cannot boot to Android System.
Thoughts.
Unfortunately still no joy one thing i have found forgot to mention is 1.8 doesn't seem to be correctly applying. By this i mean when i flash it it produces the following error message.
"E:Error executing updater binary in zip"
now i have searched and this seems to be an issue with TWRP but unfortunately i no longer have the 3e Recovery unless this can be created into a .zip for me to re-flash and get back to the Stock Finless 1.8 ROM.
Originally posted by washere View PostFactory reset in TWRP recovery
Restore your backup from sd-card
If no joy:
Factory reset
Flash 1.8 original ROM
Boot into Android then recovery
Originally posted by washere View Post... by using method 2 in link below: USB Burning Tool:
http://www.cnx-software.com/2014/04/...-amlogic-s802/RK3288 Devices
- Overview BOX (LINK !)
Can this tool be used to flash just the recovery.img ?? as i have the original to then flash Finless to rule out TWRP.
Originally posted by washere View PostTry another ROM for now
Or
Hope you unzipped download to get 1.8 ROM zip inside it.
Or
If your whole system is thrashed re flash 1.8, by using method 2 in link below: USB Burning Tool:
Guest
I don't know if there are dependent files or procedures for that recovery.img, try. Maybe your sd-card or file was corrupted. I'd say flashing the nandroid then if no good a proper FRESH ROM. I never used that tool. Try.
Originally posted by washere View PostI don't know if there are dependent files or procedures for that recovery.img, try. Maybe your sd-card or file was corrupted. I'd say flashing the nandroid then if no good a proper FRESH ROM. I never used that tool. Try.
Finally managed to resolve managed to flash original recovery image using below command from within the terminal command of TWRP this then allowed me to install the Finless 1.8 ROM all good now does seem TWRP was the issue in some way though not running the Updater Script.
flash_image recovery /path/to/recovery.img
There are currently 1570 users online. 1 members and 1569 guests.
