TWRP for Square M8 by Abdul Finished & Working: Can Backup Your Whole System
Guest
Same here Ive done 3 boxes backing up and restoring from the same SD card, with no problem, this fourth box just wont restore the xbmc files.
Originally posted by Apostle View PostIs really wierd on one m8 it it worked straight away no issues on the other 2 it did not replace the xbmc with the one from the image or the data folder. Anyone else had this issue. would re-flashing more than once be an option
Only an idea but maybe it depends on v.91 and v.92 of PCB?RK3288 Devices
- Overview BOX (LINK !)
Originally posted by Crows View PostYes all on same firmware...where are those files located?
all my boxes were same box on same FW. I installed TWRP then went to restore ticked everything to restore and let it does it's magic. it is fantastic work Abdul. just few bugs need ironing out. I will wipe a box in morning and re flash. Will get logs for you also.
I don't know if this is possible at all but this would be awesome for MX2 boxes.
Sorry i'm trying to figure how to enter adb mode, so that i can grab the files for you.
Originally posted by abdul_pt View PostAfter the restore, still on recovery, enter adb shell do dmesg > /tmp/dmesg.txt , exit , adb pull tmp/dmesg.txt and adb pull tmp/recovery.log upload them please.
Tapatalked
No I'm happy to learn looks like i gotta crack open the box and insert a jumper so that it is recognised.
Its funny I bought 10 boxes for family and friends and the first 3 restored no problem, since i have tried another 3 and all of them don't restore xbms, I've tried wiping everything, complete erase with the same result.
Originally posted by abdul_pt View PostDo you have ADB setup up ?
Tapatalked
Originally posted by Crows View PostNo I'm happy to learn looks like i gotta crack open the box and insert a jumper so that it is recognised.
Originally posted by no_spam_for_me View PostEnable ADB (Android Debug Bridge):
a. Settings
-> [Others]
-> [More Settings]
-> [SYSTEM / About MediaBox]
b. Click as often as need at [Build Number]
c. Leave [More Settings] and go back to [More Settings]
-> [SYSTEM / Developer options]
-> [DEBUGGING / USB debugging]
d. Plug in OTG (windows recognize a new device -> cancel driver setup)
e. Download and Install MoboRobo http://www.moborobo.com
f. At device at TV you will see a message "Allow USB debugging?"
=> Check "Always allow from this computer" and press [OK]
g. Download and Install 'ADB, Fastboot and Drivers - 15 seconds ADB Installer'
BTW: I unpack the .exe with WinRAR into a directory I like and use it at subdir adb...
h. Test adb with 'adb devices' -> "12345678900 unauthorized"
i. At device at TV you will see a message "Allow USB debugging?"
j. Test adb with 'adb devices' -> "12345678900 device"
k. Because I don't need MoboRobo, I uninstall it (but keep the drivers [IMG]file:///C:/DOKUME%7E1/FUN/LOKALE%7E1/Temp/msohtml1/01/clip_image002.gif[/IMG]) ...RK3288 Devices
There are currently 5399 users online. 4 members and 5395 guests.
