CSM8 PCB QUALITY !!!!
    Originally posted by Spikey818 View Post
    But this rom has bluetooth right so if I flash TWRP on my box, then restore your TWRP backup, then I should have bluetooth working if it says I have bluetooth 4.0 on my box?
    it did not understand.
    this bacup made ​​using twpr is:
    for those who have after replacing the firmware stopped working wi-fi
    it will help restore job wi-fi
      just got one piece today, and thank god it as the wifi is ap6330. I flashed twrp recovery and then flashed my backup of the s82b 108k4 latest stock firmware and everything seems to work great, replace the remote.conf file and remote works good as well. got an antutu score of 38744. wifi is really good on this better than the s82b because of the antenna. getting full 15mbps on my second floor. that's my max internet speed.
      I love this box.
        I love this box.
        True! its quite decent Box...
          spoke too soon, it works perfect after flash to the s82 backup but only until you do a couple of restarts or so, it factory resets and it also loses it's settings etc., now, i don't don't if it's the box itself or the firmware. going to flash the stock firmware now and see if it still behaves that way.
            it's probably a good box but firmware support just isn't there, also the matter of the different wifi chips. i rather get a s82b 8gb box than this. i still think the s82b are a better box.
              just and update, these boxes suck big time. went back to the original firmware for this box and still the same issue, rebooting it or even shutting it off or unplugging it makes it either go into a boot loop or it sometimes loses all it's settings. apps are still there but all data for the app is gone. i regret getting this crap box now, i guess a good looking board isn't always everything. wifi is good on this box, but that's probably due to the external antenna.
                -1i dont have that problem!!!plz try diferent sd card and before a flashing ( factory reset and remove xbmc)
                and plz no spam!sry on my bad eng
                  -2 I have no problem what so ever...
                  Go to Recovery screen ,delete factory data and wipe cache
                  install this
                  https://www.dropbox.com/s/ifktz3zvj6...mware_0725.rar
                    install this
                    do u try stanes new
                    s82 rom on csm8? (rom is prety the same like his fw for eny m8) i hope he will fix isuues
                      install this
                      What firmware is this based on? Everything wi-fi, remote, google play store etc. is working on this firmware? I have been looking buy one but working firmware without issues is a must. I hope someone can confirm, I will order one of these boxes.
                        that is stock rom
                          Already tried everything, I guess I just got a bad box. I'm also getting this error: "the machine has a serious error, need reboot to repair" All this starts happening after a reboot, or when the box is restarted, un-plugged and plugged back in.
                            i just finished trying almost everything, including factory data reset multiple times from recovery, etc., this box works great until it's either plugged out or rebooted or powered off. After that it will go into boot loop and than eventually boot up, however, all the settings etc., are completely lost.
                              I think the box is hard bricked now, I used to be able to fix it using the usb burning tool and an s82 image but not it's giving error at 2% saying usb error occur when check ddr run at romecode. Anyone know here how to fix such a hard brick? Also, when plugged in the box is displaying a red led all the time now.
                                I have same problem with one unit ,hardwere is problem i open box and i see something is not good i see they writes on board ,maybe we got test board,i try everthing all stock custom roms openelec ,linux xbmc ) all time same problem ,on start i try all softwer ,but just got bad item,i will try to fix that but i just lose my time
