i also ordered pipo p9, does that mean that the rk3288 will be buggy?
Mk902II troubles
I solved my sound problem using SPIF optical cable. I think it was the ARC function of my TV that was not working properly :/
Sound is still only in stereo BTW.
Ho and I managed to watch 4K H264 Video in real 4k (there is a clear difference with 1080p)
I confirm this is only working with the built in player.
And the "Galery" only show pictures in 1080p
Originally posted by xtreo View Post...
Data transfer:
Has each USB port separate controller? Or MK902II has only one controller with USB HUB? It is important for copying data from one USB hdd to other... What is real speed of copying between two USB ports? Has MK902II dedicated LAN port or it is shared with something else (for example with USB like on Raspberry Pi)? Has it real gigabit LAN? Can I realy copy file through LAN to first USB drive ~40MB/s and to second USB drive ~40MB/s at the same time?
Now I know a little bit more about the SoC layout of the RK3288:
- one USB OTG 2.0 Host
- two USB 2.0 Host (but one only supports 2.0 and not 1.1 (ECHI))
- the WiFi module seams to be connect to a separate port at the SoC (SDIO 3.0 / UART) but could also use one of the two USB 2.0 Host (depends on the module, but the AP6xxx seams to use the SDIO 3.0 / UART)
- the Ethernet can connect to the GMAC at the SoC via a PHY (like the rk3188)RK3288 Devices
- Overview BOX (LINK !)
Been testing for bit newest build and latest rom havent tried the 4 k funtion yet but everything working out of the box so far xbmc included snappy and clear. ill test some of the other roms as soon as u get set up on windows hate.....
LolMany devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Originally posted by scooter2014 View PostBeen testing for bit newest build and latest rom havent tried the 4 k funtion yet but everything working out of the box so far xbmc included snappy and clear. ill test some of the other roms as soon as u get set up on windows hate.....
Lol
Everyone Ive tried it usually goes very bad.
Originally posted by vegarRingdal View PostTell me if u find one that have working netflix :-)
RK3288 Devices
RKM MK902II 16GB no sound on AV Receiver
Does any one have the RKM MK902II working with sound through HDMI cable to a AV Receiver?
A change all options on sound system and can´t get any sound on the AV, i have a Onkyo TX-SR608 receiver.
But when i plug the HDMI cable to the tv, it has sound!!!!
Can you help?
I don't have a MK908II but it seams to be a generally problem at rk3288 at the moment that many AVR at HDMI pass-trough doesn't work... at other devices I know they are working hard at the FW to fix it...RK3288 Devices
Originally posted by shupifero View PostDoes any one have the RKM MK902II working with sound through HDMI cable to a AV Receiver?
Can you help?
And when I switch my TV input and goes back, my RKM is crashed and I have to reboot multiple times to get it back ...
Can you help?
Originally posted by DarkCyrix View PostI tried every 4k video on this site, the player keeps saying he can't read the file
I made another test, I made an app that displays the current resolution, it shows "1920x1080" in 1080p60 and in 2160p30.
So there is no real 4k the device juste upscales the buffer before sending it through HDMI ...
Can you share your APP?
Also note that probably the UI is 1080p, but does not mean your device can not play 4KAndroid TV Box direct from China. English & Español
There are currently 1748 users online. 1 members and 1747 guests.
