I am very new to using android as a way to interact with media on the TV.
For years I have been using xbox, custom build computers and Raspberry Pis as media centers.
Yesterday I started experimenting with the Minix X7 and was wondering if there is a way to use the build in infrared sensor to interpret the button presses of the TV remote.
I know that the Neo X7 does not support CEC but this would be a nice way of eliminating unnecessary remotes.
The way I usually did it with Raspberry pis is attaching an infrared sensor and then using lircd so that the os knows how to interpret the buttons.
This was a very cost effective solution compared to the flirc usb adaptor.
Is there a way to do the something similar with the already build in Infrared sensor in the Minix neo X7?
