[ROM] Prahjister ROM 1.0 MK808B Realtek WiFi
    720 and 1080
    Stutter Fix
    Netflix Fix
    Browser Changed Not perfect yet.
    Removed a bunch of crap apps
    KitKat Launcher
    init.d support
    CPU script in init.d so you do need to run setcpu. It sets interactive and high speed. If you dont have a good power supply you can edit and change 1608 to something slower.
    latest spmc in the /system/usr directory
    DDR is oc....on 1080 it is a must but on 720 just makes it smooth and doesn't make any more heat. DDR is set to 466.
    I recommend 720 but 1080 works well.
    Launcher will look and act weird until you update Google search.
    To get your device in flash mode use a pin in the hole opposite the blue light...while holding plug in usb to pc. When you see found rkandroid you can let go.
    To flash 1080 right click in the area with all parameters and load cfg. Find the 1080.cfg in the base directory.
    Before launching spmc push the down arrow on navigation bar. To bring it back swipe up from the bottom. I have been leaving it closed all the time.
    OK Google works if you have a mic.
    After install set time zone. Go into developer options and set all 3 animation scales to .5. Set screen scale. I set my pointer speed to full under language and input. Under security check unknown sources.
    I like this base so much i am going to see if i can port over to the original MK808b and non b. Antutu is not as high but it seems better. 13160
    If you have original and don't use wifi or bt....give this a shot. I cant test but i believe pass-through works. All 3 options are there.
    Working on a script to install all apk files that are on external sd card in a specific directory. Will post script when i get it figured out.
    Windows drivers included. App to use your phone or tablet as remote is included.
    Download Link
    Can i use the ROM with MK808 (without B)?
      Sure but WiFi won't work. Use 1.2 if u need WiFi it is for original b and non b. I need to ask mod to change the title. The (b) means for b and non b. It is confusing. It is for 901 and 903 wifi
        Will try this out tonight
        can you please clarify the setcpu thing? Id rather run at safe speeds and not cook another power supply. Once this is set does it continually have to be set up one restart or unplug? I say this because I give this to people with little to no computer knowledge or know how. Thanks P!
        720 is great enough for me too
          Just delete the cpu script in /system/etc/init.d
            Thanks P.
            Loaded the 720 and updated google search. Everything looks great. Wish there was an easy way to incorporate a auto hide feature but I'm glad this is working now! Is the 720p running at really high clocks? Because I don't feel too much heat when streaming stuff in xbmc. U think its safe to leave on all the time? On a side note: spmc runs absolutely amazing. So much faster then other firmwares on the older style. I get an axel downloaded error that's linked to icefi/ms. Other then that simply OMAZIng!
              Thanks P.
              You will want to install standard xbmc for plugins.
              i tried to make script to auto hide....but didn't work.
              Mine is on all the time
                Is wifi speed the same as the stock rom?what stock rom did u update from pass_00
                  Thanks P.
                  Hey fullscreen! Works great from the play store for auto full screen....no flicker
                    I used a newer one from manufacturer. I'll post actual build in a minute.
                      duplicate
                        lhh_V__j2102 #13 kernel it is compiled 1080...i helped pass patch his 1080 with the tool I made
                        104j2_19-07-2014 is the software version
                          zip pw?
                          Originally posted by prahjister View Post
                          http://www.mediafire.com/download/tj...j2104-0721.rar
                          zip pw?
                            geekbuying.com
                            forgot about pwd
                            none of the fixes are in it.
                              FYI for the YouTube app use version 5.0.21....latest version doesnt work.
