[ROM] Prahjister ROM 1.0 MK808B Realtek WiFi
Originally posted by mowgli View PostHow is this possible? Note the Antutu score.
http://4pda.ru/forum/index.php?showt...ost&p=34018925Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Originally posted by prahjister View PostNewer antutu gives higher score same device
He says that the score on the stock ROM was 10000 after flashing it it was 17000+.
By-the-way, he flashed you v5 beta ROM which gave him this high score.
Originally posted by mowgli View PostIf that was the case, the score would be the same (or almost the same) before flashing it and after.
By-the-way, he flashed you v5 beta ROM which gave him this high score.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
THANK YOU!!!
I just wanted to give you a shout out! I bought my box (mk808b with rk3066)on amazon a couple weeks ago and since then have been trying to find a ROM that works- I'd almost given up hope. Phinc finally directed me to this site...hooray! Hallelujah! This has been an EPIC first time trying to flash a custom ROM. I learned so much... especially to back up everything (even if you have the "original" ROM from the seller...which actually ended up bricking my device and led to the world of shorting pins). Thank again prahjister!!
Originally posted by prahjister View Post720 and 1080
Stutter Fix
Netflix Fix
Browser Changed Not perfect yet.
Removed a bunch of crap apps
KitKat Launcher
init.d support
CPU script in init.d so you do need to run setcpu. It sets interactive and high speed. If you dont have a good power supply you can edit and change 1608 to something slower.
latest spmc in the /system/usr directory
DDR is oc....on 1080 it is a must but on 720 just makes it smooth and doesn't make any more heat. DDR is set to 466.
I recommend 720 but 1080 works well.
Launcher will look and act weird until you update Google search.
To get your device in flash mode use a pin in the hole opposite the blue light...while holding plug in usb to pc. When you see found rkandroid you can let go.
To flash 1080 right click in the area with all parameters and load cfg. Find the 1080.cfg in the base directory.
Before launching spmc push the down arrow on navigation bar. To bring it back swipe up from the bottom. I have been leaving it closed all the time.
OK Google works if you have a mic.
After install set time zone. Go into developer options and set all 3 animation scales to .5. Set screen scale. I set my pointer speed to full under language and input. Under security check unknown sources.
I like this base so much i am going to see if i can port over to the original MK808b and non b. Antutu is not as high but it seems better. 13160
If you have original and don't use wifi or bt....give this a shot. I cant test but i believe pass-through works. All 3 options are there.
Working on a script to install all apk files that are on external sd card in a specific directory. Will post script when i get it figured out.
Windows drivers included. App to use your phone or tablet as remote is included.
Download Link
'Too many users have viewed or downloaded this file recently. Please try accessing the file again later. If the file you are trying to access is particularly large or is shared with many people, it may take up to 24 hours to be able to view or download the file. If you still can't access a file after 24 hours, contact your domain administrator.'
Thanks!
Originally posted by Hyperium View PostCan I please get a mirror because it seems that Google isn't letting me download the file. I just get this message
Thanks!Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Originally posted by LoneRider View PostHello Sir please allow download for the firmware
Please use this one.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
There are currently 3145 users online. 0 members and 3145 guests.
