[Pipo-Project]Freaktab to Continue Pipo Firmware Support on Discontinued Models
Originally posted by d33 View Post
Donate to Finless
Originally posted by MatadorIs the multi-kernel repo free? Vor only for freaktab developers?
Currently it is housed on GitHub under my account "Dee-UK"
Using my ipad so apols for any stupid ios spelling 'corrections'Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
I'm working on a kernel for a Odys noon pro which is said to be just a repackaged Pipo M1 pro.
I started off with your git repo and the defconfig and board file for Pipo M6 max as the case looks very much the same so I hoped the board would be at least very similar and the main difference being the display panel.
My goal is building a linux kernel.
The kernel boots and the framebuffer, the keys, and USB work ok.
The touchscreen behaves like a touchpad, but I think this is a input driver problem on the Xorg side.
I'm asking for your help regarding wireless connectivity. I seems that MT5931 is used for WiFi and MT6622 for bluetooth. I am stuck because there seem to be 4 configuration settings regarding these chips in 3 different places ("/device drivers/network device support/Wireless LAN/" and "/device drivers/MediaTek Connectivity Combo Chip Config" and "/drivers/Misc devices/ MTK wireless chip configuration").
Can you help me with:
* how to configure the kernel for MT5931 and MT6622
* which board file to start off when working on a Pipo M1 pro
I'll be glad to share any progress to your repo or on this forum
Regards
Alan
Wifi should be configured as MT5931 from main selection menu and then MT6622 support toggled seperately. One of the tablets (M9 Max) has this config
CONFIG_MT5931=y
CONFIG_MT5931_MT6622=y
CONFIG_MTK_MT5931=yMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
I got Wifi running, thank you for your help. Still struggling with BT init, but that is not a kernel problem.
The M1 pro is one of Pipo's 1.6GHz 9,7" 4:3 tablets, by the way.
M1: rk3066 1024x768 IPS
M1pro: rk3188 1024x768 IPS
M6: rk3188 2048x1536 retina IPS
As they all have very similar cases down to the arrangement of connectors and buttons, I hoped the boards within would be related if not the same.
Originally posted by kralan View PostI got Wifi running, thank you for your help. Still struggling with BT init, but that is not a kernel problem.
Glad to hear you made progress. Please push your working kernel config file back when you are successfulMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
There are currently 1403 users online. 1 members and 1402 guests.
