Sent from my Minix Neo X8-H using Tapatalk.
Can someone explain why xbmc needs permission su?
Just curious if someone can explain why permission is needed for all the chmod666 etc etc and what it all means with the m8/xbmc it's the only one that's rooted I have that needs all the permissions.
Sent from my Minix Neo X8-H using Tapatalk.Tags: None
Originally posted by tampametal View PostJust curious if someone can explain why permission is needed for all the chmod666 etc etc and what it all means with the m8/xbmc it's the only one that's rooted I have that needs all the permissions.
You don't need root to fix the underlying fault but if you have root it's easier to correct the issue as it's done for you on boot. I just screen shot the permission requests then changed them from the terminal, but you can do the permissions swap with es file explorer so the fix is permanent and I don't get the pop ups.
Hope that makes sense....Minix Neo X7 - Wasser 1.0.4 OC'd - Kodi-helix with passthrough
Beelink M8B - Wasser 1.0.3 - Kodi-helix alpha 2 + SPMC
Originally posted by ant View PostI can try dude.... if the permissions are not correct on certain files within the firmware issues can arise with hardware decoding on AMLogic devices.
How do you do permissions swap with es file explorer???
southpole
Originally posted by southpole View PostHow do you do permissions swap with es file explorer???
southpoleMinix Neo X7 - Wasser 1.0.4 OC'd - Kodi-helix with passthrough
Just a small tip if the pop up notifications from su annoy you when xbmc boots up each time. The easiest way to get rid of them is to enter su app > settings > "uncheck show notifications"
SuccessMinix Neo X7 - Wasser 1.0.4 OC'd - Kodi-helix with passthrough
Originally posted by ant View PostJust a small tip if the pop up notifications from su annoy you when xbmc boots up each time. The easiest way to get rid of them is to enter su app > settings > "uncheck show notifications"
Success120" screen, EPSON 6100W, YAMAHA RX-V775, B&W 603 (front), B&W CC3 (center), B&W DS3 (surround), Boston Acoustics SoundWare XS (front heights), SVS SB-2000 (subwoofer)
M8 TV Box Codesnake's OpenElec 6.0.3
Tronsmart MXIII+ (v108L1) + KODI 16.1 (Jarvis)
There are currently 5450 users online. 3 members and 5447 guests.
