Pipo P4 RileyROM 1.5 (Android 4.4.4)
    Originally posted by m1pnk View Post
    i found a cool version of xbmc that has solved all my problems.... fingers crossed..... live tv seems fine and lack of crashes on the 3288.
    its the spmc one by the way
      Pipo announced (1 hour ago on pipo bbs) a new firmware and in that firmware the battery drain should be fixed
        is there a link ?..... many thanks
          It's only announced, when i got a link i will share it here.
            does that mean they are aware of problem and are working on it or there is new firmware ready ?
              They're aware of the problem and will fix it in the next firmware. When i know more i will let you know, maybe riley can also update that firmware in rileyrom 1.5.2
                If its a new firmware it will be 1.6.
                Randy
                  I'ts looking good with that file Riley. For the last 13 hr and 50 minutes i used it 26 minutes and i lost 6% in total. Last night i used in 9 hours 3 procent on standby. Avarage in +/- 14hr is 0.4%/hr
                    With the same file I am looking good as well although battery monitor is now showing cell standby time while the previous one didn't.
                      On arctablet, a user named 'soukouzen' replied with a new firmware. The only problem is that i don't know if it's a employer from pipo or not. In the file name you can see 20140901 so i guess it's a new one and also #613, so maybe a new kernel?
                      http://pan.baidu.com/s/1ntiHqmX for WIFI version.
                        I'm downloading updates for both wifi and 3G. I hope to have something today.
                        Randy
                          RileyROM v1.6 is now available here:
                          Randy
                            prob a dumb question but on twrp it is asking for a device name..... pipo p4 not listed ?...... thanks.... pinky
                              You can put anything. It's for the backup file name. It must not be seeing the P4 in build.prop.
                              Randy
                                Too little info to say anything.
                                I'm curious to know if it works or not.
                                Tapatalked
                                if [ $up.post.type = $type.two.lazy.to_use_google ] || [ $up.post.type = $type.silly_question ];
                                then mv $user.contact.up.post /.trash; set response($response.type = ignore);
                                $user.up.post.ignore_in_future = true; fi;
