1. Download the ROM Kit for your version (wifi or 3g).
2. Unzip the kit on your desktop, or wherever you downloaded it.
3. Open the AndroidTool.exe
4. With your tablet turned on, with USB debugging turned off (in settings), plug in the USB cable. Be sure to always use the USB cable that came with the tablet.
5. Make sure the USB drivers are installed for the Rockchip device. (see the First Time User's Guide for details, if you are having trouble)
6. You should see the tablet recognized by "Found One MSC Device" in the bottom of the tool.
7. Click the "Switch" button to reboot the tablet to flash mode. The screen will turn black.
8. Click "LowerFormat". It will count to 100% (very quickly).
9. Click "Run".
10. When the flash is finished, the tablet will boot into stock recovery and will format your partitions.
11. First boot will take a little longer than usual...just be patient and watch the boot animation.
12. Once the tablet boots to the system...you will have a fresh, rooted system to work with.
This ROM is:
Rooted
Debloated
English as default language
init.d support added
Busybox commands added
Google Play Store fixes added
Reboot app by Petrus
Your choice of 4, 6, 8, 10 and 12gb user app space (select the parameter file you want to flash) The default is 4gb
Thanks to Geekbuying.com for providing me this and many other Pipo tablets to develop.
This ROM contains a working version of TWRP Recovery which will be installed during the first boot. You will notice the stock recovery appear during the first boot to format all of the partitions...then you will boot to system and TWRP will be installed...just wait a couple of minutes for this process to happen before shutting down the tablet. You can use the Reboot App to reboot to TWRP.
v1.5 wifi
v1.5 3G
Here is v1.5.1 which contains the modified framework.jar by hueb_s which activates multi-user
v1.5.1 wifi
v1.5.1 3G
Enjoy!!!!
Please.....Don't forget to donate....this helps me continue further ROM development.
