IdeaUSA DTV001 / iDeaTV / DroidTV / HDMI Stick with MTK Wi-Fi and BT chip
    The IdeaUSA DTV001 / iDeaTV / DroidTV / HDMI stick is a RK3066-based, Chinese-built device re-branded by USA distributor IdeaUSA and currently being sold by retailers Frys.com, Buy.com, BestBuy.com, PCRush.com, BeachAudio.com and others
    Note: the USA distributor does not offer any firmware updates for this device ... so, this thread and forum are the best place to look].
    <detailed photos attached below>
    Chipset:
    Rockchip RK3066 -- Dual-Core ARM Cortex-A9 processor with Quad core Mali-400 GPU (Open GL ES 2.0, Open VG 1.1 support)
    Texas Instruments T659102 / TPS659102A1RSL -- Integrated Power Management IC
    Mediatek MT5931SA -- All-In-One Wireless LAN
    Mediatek MT6622N -- Bluetooth v2.1 + Enhanced Data Rate (EDR)
    SPECTEK PFB15 / FBNL84A69K3BAAWP-AR -- 8GB MLC SSD
    Mira PDJ2108DEBG -- 2G bits DDR3 SDRAM (256M words x 8 bits) or (32M words x 8 bits x 8 banks) [4 each, 1 GB total]
    Motherboard (green-colored PCB) is silk-screened "T005-V4 ...20121230"
    ... maybe identical to Hotack T005-V4 and Rikomagic MK802IIIS/BT
    ... and therefore may utilize such firmwares as;
    Rikomagic MK809II
    and MK802IIIS/BT ... Ugoos UG007II ... iMito MX2
    Known working firmware:
    UG007ii_public_MTK_20130820.zip (247 MB)
    FW Image: update.img (423,140,816 bytes)
    FW Ver: 4.1.01
    Boot (Loader) Ver: 2.03
    FW Time: 2013-08-20 11:29:30
    Boot (Loader) Time: 2013-08-08 20:35:13
    Support: RK30
    Model number: rk30sdk
    Android version: 4.2.2
    Kernel version: 3.0.36+ ... zs@hotack-desktop#402 ... Tue Aug 20 10:21:32 CST 2013
    Build number: rk30sdk-eng 4.2.2 JDQ39 eng.zs.20130820.112013 test-keys
    Vendor software version: RK3066_R-BOX_ANDROID4.2.2-SDK_V1.0.0_130308
    p.s. I've tried using the more recent Android 4.4 (Kit-Kat) for RK3066 devices with MTK chip (posted by Shomari) HERE which works beautifully EXCEPT for a Bluetooth issue (i.e., pairs with Bluetooth devices, but does not fully communicate?) ... if anyone knows of another Kit-Kat firmware for Hotack T005-V4 or Rikomagic RK802IIIS/BT with MTK chipset (or workaround/patch for the foregoing Bluetooth issue), please reply to this thread. Thanks!
    IdeaUSA DTV001 / iDeaTV / Rockchip RK3066 HDMI Stick
    Chipset Details for IdeaUSA DTV001 / iDeaTV / DroidTV / HDMI Stick with MTK Wi-Fi and BT
    Here are more chipset details for IdeaUSA DTV001 / iDeaTV / DroidTV / HDMI Stick with MTK Wi-Fi and BT ... from the production sample mentioned and pictured in the previous post ... green PCB marked: "T005-V4 ... 20121230"
    Factory Firmware Info (from parameter dump):
    FIRMWARE_VER: 4.0.4
    MACHINE_MODEL: rk30sdk
    MACHINE_ID: 007
    MANUFACTURER: RK30SDK
    MAGIC: 0x5041524B
    ATAG: 0x60000800
    MACHINE: 3066
    CHECK_MASK: 0x80
    KERNEL_IMG: 0x60408000
    #RECOVER_KEY: 1,1,0,20,0
    CMDLINE: console=ttyFIQ0 androidboot.console=ttyFIQ0 init=/init initrd=0x62000000,0x00800000 mtdparts=rk29xxnand:
    0x00002000@0x00002000(misc),
    0x00004000@0x00004000(kernel),
    0x00008000@0x00008000(boot),
    0x00008000@0x00010000(recovery),
    0x000C0000@0x00018000(backup),
    0x00040000@0x000D8000(cache),
    0x00280000@0x00118000(userdata),
    0x00002000@0x00398000(kpanic),
    0x00100000@0x0039A000(system),
    0x00B46000@0x004BA000(user) [derived from formula below]
    Note: Total size of 8192 MB NAND chip in Hex: 0x1000000 (512 byte blocks)
    10000000 (NAND size) - 4BA000 (user start) = B46000 (user count) *
    * 6,052,380,672 decimal bytes
      MK809II fake
      FIRMWARE_VER: 4.0.4
      MACHINE_ID: 007
      MAGIC: 0x5041524B
      ATAG: 0x60000800
      MACHINE: 3066
      CHECK_MASK: 0x80
      It's appears that you have the same problem that me. I tried some ROMs, Finless, Shomari and others found on the internet. Just one works for me, but not working with MTK chipset, such as BT too not worked.
      If you get a .ko files for mtk to this kernel in this link may be it will work.
      I contact chinese store sold me it and he passed me this link
      You can try too, try search anothers roms in this link, there are several roms.
      If you have any idea, please contact-me. The chinese store will send me another, but I try to run linux.
      Regards.
        Working Firmwares for MTK MT5931 / MT6622, BT Patch, VolksPC Android + Linux unified system
        Originally posted by romulofranco View Post
        It's appears that you have the same problem .... I tried some ROMs, Finless, Shomari and others .... Just one works for me, but not [fully] working with MTK chipset, such as BT [Bluetooth] not worked.
        I contact Chinese [vendor] and he passed me this link;
        Hello romulofranco,
        The above link you provided is a fully working Android 4.2.2 firmware for RK3066 device [such as my DTV001] with Mediatek MT5931SA (WLAN) + Mediatek MT6622N (Bluetooth) ... I have fully tested it.
        Archive: MK809II UG007New.rar (186.1 MB)
        Firmware: cyxtech_rk30_dongle_mtk_131118.img (340 MB)
        Firmware ver.: 4.1.01 time: 2013-11-18 11:06:25
        Loader ver: 1.34 time: 2013-06-21 16:59:31
        Support: RK30
        Model Number: rk30mtk
        arron@develop-server #5
        Mon Nov 18 10:14:58 CST 2013
        Build number: rk30mtk-eng 4.2.2 JDQ39 eng.arron.20131118.181739 test-keys
        During my testing, I found;
        (1) The firmware is rooted
        (2) The Wifi and Bluetooth are fully working
        (3) Power icon = 'Screen off' only (meaning 'Sleep', with power always on ...
        wake with mouse or keyboard) ... no 'Restart', no 'Power off' function ...
        During my testing, I also found text strings "/data/MTK_MT6622_E2_Patch.nb0" and "/system/etc/firmware/MTK_MT6622_E2_Patch.nb0" inside this file;
        /system/lib/libbluetooth_mtk.so
        Which may indicate some manufacturers are adding a Bluetooth patch for specific MTK chipsets ... the indicated file is also present in filesystem;
        Another good Android 4.2.2. firmware is;Also this custom, rooted Android 4.2.2 (Finless ROM 2.0) firmware;
        You also suggested;
        http://ugoos.net/mk809ii <ug007ii_mk809ii_public_MTK_20140516_andriod 4.4.rar (T005_public_MTK_12_20140517_V4.4.img)>
        You can try [other] roms in this link, there are several ....
        So far, I have tried many Android 4.4 firmwares, mostly unsuccessful ... but
        I will try "adb push" to repair Bluetooth files for Android 4.4 firmwares ... and let you know if I have any success.
        Lastly, you wrote;
        I try to run linux.
        Finally, I have good news and success!! It is very easy to run Android + Debian Linux unified system using VolksPC custom firmware:Once you have the VolksPC firmware running on your device, you will need to add the latest Debian Linux system update linuxfs.img using a freshly formatted microSD card;Be sure to follow instructions (see: "Installation Procedure") ... do not disturb the system during the update (wait 5+ minutes for system to auto reboot)...
        You can read more "how to" regarding VolksPC Android + Debian Linux at the FreakTab thread below;
        Run-Android-and-Debian-Applications-on-you-RK3066-device
        (VolksPC)
        http://www.freaktab.com/showthread.php?16299-Run-Android-and-Debian-Applications-on-you-RK3066-device
        Best Wishes,
        Dobbs
          Hello romulofranco,
          Support: RK30
          You also suggested;
          Lastly, you wrote;
          (VolksPC)
          Best Wishes,
          Dobbs
          Hi revbobdobbs,
          Thanks for your answers.
          I tried all this roms, but no success. My motherboard device is exactly like this:
          I tried VolksPC firmware but the screen stopped in an image like this: Robot Android in center of TV and I waited for about 5 minutes, but nothing happens.
          The chinese vendor will send me a new Mini PC, but I want to recover it.
          Can I put a RK3188 firmware just test in this device (RK3066)?
          PS: Sorry my english...
            Finding the correct firmware for your device
            Hi revbobdobbs,
            Hello romulofranco,
            I've sent you a private message in your language. I am posting here for the benefit of other users.
            If you are sure that your RK3066 device is the same as riclixo's MK809II fake, silkscreened with "GXT809IIx32_V1.32") ... then I suggest you start your own thread "Need firmware for MK809II fake 'GXT809II'"... including detailed photos of your device.
            Almost all devices are unique (although many are using the same chipsets) ... due to GPIO ("General Purpose Input Output") generic pin implementation specific to each device.
            p.s. I don't believe it would be possible to swap RK3066 and RK3188 firmwares without customizing the kernel for your device.
            Best wishes finding the correct firmware,
            Dobbs
