Having issues with my Rc11 wireless remote..
Hi guys, recently brought and wireless rc11 remote off **** and I can't seem to get it working properly, it's like the signal isn't strong enough, my remote has fresh batteries and I've tried the configuring as the manual states but the problem still persists.. Is it an issue with my M8? Or dodgy remote?
ThanksTags: None
Are you also using WiFi at 2.4GHz? If yes, try to use a USB extension cord or a USB-HUB and place the dongle as fare away as possible...RK3288 Devices
- Overview BOX (LINK !)
Originally posted by L3e View PostThanks for reply - Tried turning off the wifi and using Ethernet but still no luck, it does work o.k - ish from about a meter away, any further and it's useless and very frustrating to use
I can confirm what "no_spam_for_me" and "TMx" suggests of getting a usb extension.
Had a Mx2 box with Rc11 and worked flawless from other side of room,but when I got M8, i struggled with it the same way you did.
I got the idea there was interference and plugged in my 1m extension cable and then it just worked flawlessly
isOriginally posted by Phrozin View PostI can confirm what "no_spam_for_me" and "TMx" suggests of getting a usb extension.
I got the idea there was interference and plugged in my 1m extension cable and then it just worked flawlesslyBugs are Sons of Glitches!
JustMe
As far as I could determine it was interference from the M8 side. The reason I say this, is that the Rc11 worked perfectly on my other box,but started giving trouble on M8. As soon as I plug in a usb extension cord it worked like normal again,weird.
I couldn't determine what caused interference
Just a bit of and update to this thread, I tried having the receiver on the end of a 2m long extension cord and the problem still persisted.
So in the end I brought a droidbox VIP remote and it works perfectly!
Only problem is now I have to try and get a refund for the faulty remote...
Anyway thanks for the helps guys!
There are currently 2616 users online. 1 members and 2615 guests.
