Good afternoon dear developers! i confronted with th problem on beelink r89 16gb OS 110k4. During connecting of mouse a4tech x7 710mk and keyboard omega kb-2300 keys stick but if disconnect the mouse all will be alright. Also i have a problem with resolution
R89-Accessories support(Camera/Remote/3G dongle/USB devices/SD card...)
Originally posted by phira600 View PostMy Lenovo N5902 isnt working properly with the R89. When I use the mouse pointer the screen scrolls too. The pointer moves ok, but so does the menues... Very annoying since you cannot control everything using the stock remote.
I am using the same without any issues.
I would like an all in 1 remote. I dont like using 2 different remotes (1 for TV 1 for Android Box)
Can someone recommend a single controller that has the following:
- Backlit (keys light up, i need this for the dark)
- IR sensor (i want to use it to replace my TV remote for normal watching)
- Keyboard
- Mouse (i want to be able to use it as a mouse)
I have Beelink R89 RK3288
Having problems with my rii i8+ keyboard and beelink r89.
While this keyboard with touchpad works fine with other boxes on the r89 i get some strange behaviour.
If i press a button chances are big that i get up to 10 time the same button.
Really strange, as the other (sometimes very similar) keyboards sporije fine.
Originally posted by bloodgnome View PostHaving problems with my rii i8+ keyboard and beelink r89.
Really strange, as the other (sometimes very similar) keyboards sporije fine.Easy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
Really strange, as the other (sometimes very similar) keyboards sporije fine.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
I picked up a rock candy ps3 controller from Walmart today. Been wanting to get an inexpensive controller. It works well. I'll post the kl file tomorrow. For $20 it works well...
I did notice some stuttering while using. Device freezes for half a second while navigating.Last edited by prahjister; 08 December 2014, 15:23.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
R: R89-Accessories support(Camera/Remote/3G dongle/USB devices/SD card...)
Originally posted by TitoXx View PostJust found out my OTG port is not working at all. Tried different otg cables without success. I cannot update software the traditional way...What are my options Oman?
There are currently 3017 users online. 1 members and 3016 guests.
