M8 New Board? bricked with 1.7?
Originally posted by TMx View PostRK3288 Devices
- Overview BOX (LINK !)
Originally posted by TMx View PostWait for Bob Mate He is From US hence He'll be around here according to their Local time...
Originally posted by beats View PostAny ideas why 1.7 would brick this box Bob? I assume it's something todo with the stock firmware that was already on it rather than ram differences etc?
My ROM wipes everything so no previous ROM should cause a problem.
Attack of the CLONES is already happening
Maybe, maybe...
Maybe first you need an OTG
(BUT if I correct informed there doesn't exist an img version for flashing via usb_burning_tool at PC)
Then there exist a way for the round ones:
the tools you can find at http://www.tronsmart.eu/downloads/
BUT, because I don't know if this little chip also exists at you board you have to know, which pins at the NAND you have to short...
BUT, because no img version for flashing via usb_burning_tool at PC exist, you have to find out, if it also works with the "normal zips for SD card" (which exist for flashing/update at your device) at this special SD card........ ???
so maybe maybe maybeRK3288 Devices
Hello freaktab! I purchased two identical boxes. Same pcb, build number and kernel . I also tried to upgrade to 1.7 with identical resultsseeing as the hardware is different and with the previous results, is it safe to say do not try this on my second box ? Probably a stupid question but I am pretty new and currently lack alot of the technical knowledge
On a side note just wanted to say thank you to all the freaktab members. I've been reading the forum for a couple weeks and what a great community. Knowledgeable, helpful and curtious. I'm learing lots !
J
Originally posted by xray View PostHello freaktab! I purchased two identical boxes. Same pcb, build number and kernel . I also tried to upgrade to 1.7 with identical resultsseeing as the hardware is different and with the previous results, is it safe to say do not try this on my second box ? Probably a stupid question but I am pretty new and currently lack alot of the technical knowledge
J
Originally posted by fcpchop View Postso how can we tell if the boxes we get in have the correct hardware for finless?
The rest you can find at this thread..RK3288 Devices
There are currently 1887 users online. 1 members and 1886 guests.
