I'm trying to follow these instructions: http://www.cnx-software.com/2013/03/...3188-mini-pcs/
However, they're not really clear. So I guessed that I needed to have it plugged into my TV so that I can boot it up and see the screen. I brought my laptop to beside the TV. So I have one plug in the DC outlet so it can turn on. I have another mini usb coming out of the one on the side, and ready to plug into my computer. I turned on USB Debugging, and then, while the TV stick is still in the operating system, I plug in the USB into my computer (from the one coming out of the side of the TV stick).
But nothing happens. So I figure I need to push the paperclip into the little hole on the side, hold it in, and then plug in the USB into my computer. Still, nothing happens. I already have all the drivers installed from the previous instructions and RKAndroidTool.exe connected with it (but I didn't do anything after that point for fear of doing it without the stock rom as a backup). I was previously about the install a custom ROM through these instructions: http://blog.geekbuying.com/index.php...ore-tv-sticks/
But I stopped short because I was afraid of doing it without backing up my ROM.
So it seems like it will only connect when the TV stick is shut down and not in the operating system?
What am I doing wrong?
When I'm looking for a rooting method, should I be searching for MK809III SK3188? Or should I be searching for rk31sdk 4.2.2 (kernel is 3.0.36+)?
I don't understand if I'm supposed to have the TV stick on or off (it's confusing when they're talking about a "reboot"). All the instructions I find are vague and assume people already know what they're doing.
*Edit* Sorry about the title. I forgot to put a question mark so that it's not mistaken as a tutorial, when it's only a question. Moderators, if you are able to change my subject title and add a question mark or "help" or something, feel free to do so.
