R89-Android OS / Launcher / UI.... issues - feedback here
What I'm missing at WiFi is the possibility to enter a static IP...
And also missing the information about Sub-net, DNS and GW....
EDIT:
OK, I find out, that's only missing at "unsecured" WiFi's
At that moment I use a "secured" WiFi I have to enter the key and there I can also check "Show advanced options"... BUT not at "unsecured" WiFi's because it automatically connect at that moment I select it and so no way to handle the IP
I have an input issue. When I type on a wireless keyboard or an airmouse almost always the letters stick and it types the same letter continuously like I have my finger pressed on the button for a long time
I test RII Mini i25,dont find the issue...which airmouse you used?
Location services are not available on the r89. Does anyone else have the same problem? Also it says that i dont have space even though i have installed only7-8 apps
Will check them,thx.
Easy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
BTW:
I don't really need it so I don't really miss it, but I recognized, that at my TV I only get
1920x1080p-60
1920x1080p-50
but not also
1920x1080p-30
1920x1080p-25
or
1920x1080p-24
And I know that my TV is able to handle 1920x1080p-24 or 25 because I remember that I had tried it at amlogic (x8-h) but don't use it because of stuttering mouse pointer...
(ATI at NB say 25 and 30 but both output doesn't work (no signal) )
Which log at which moment do you need (if you want to have it)?
EDIT:
My SAT-Receiver can handle -> TV show
23 -> 24
24 -> 24
25 -> 25
29 -> 30
30 -> 30
50 -> 50
BTW:
1920x1080p-60
1920x1080p-50
but not also
1920x1080p-30
1920x1080p-25
or
1920x1080p-24
EDIT:
23 -> 24
24 -> 24
25 -> 25
29 -> 30
30 -> 30
50 -> 50
The whole process by Syslog
I think init.d isn't a problem to realise hand-made by my self, but it seem that nfs is missing at the kernel, because I get this:
Code:
root@rk3288:/ # mount -o rw,remount /
root@rk3288:/ # mkdir /mnt/XPFilme
mkdir /mnt/XPFilme
root@rk3288:/ # busybox mount -t nfs 192.168.2.1:/XPFilme /mnt/XPFilme -o ro,intr,soft,udp,nolock,rsize=8192,wsize=8192
2.1:/XPFilme /mnt/XPFilme -o ro,intr,soft,udp,nolock,rsize=8192,wsize=8192 <
mount: mounting 192.168.2.1:/XPFilme on /mnt/XPFilme failed: No such device
But wondering in that I can see it at the 'haneWIN NFS Server' at [Mounts] (the box IP) so it seems that a part/little bit of the connecting process is working???
Yes I know, but I ask my self why? Because of the tests with the SAT receiver I know the TV can also handle 24/25/30 (and it shows me that I remember correct that at s802 (don't own it any longer) the 24 works) ...
Code:
mkdir /mnt/XPFilme
