Well when I called tech support for all of this I got the usual run around and they tried to get me to do another factory reset and this and that and I almost had them just send her a new one until they asked me for the receipt of the original so they can confirm when I bought it. Well at this time I think it got tossed on accident buy are roommate because we keep tech receipts know nextbook wont do anything cause I cant show proof of when i bought it. So is there anyway to convert it back to the firmware it had on it that actually worked? Or shoudl I try and just re-run the update on it?
Nextbook8 NX785QC8G problems that tech support wont help me with.
Okay I got my wife said nextbook in the title. Well instead of doing research like a dummy before updating it to the new firmware on their site I did it. Well it worked fine for like a week then out of the blue when she went to turn it on it wouldn't come back on. It would get to the Nextbook screen then kick back off. Well I got it to come on by getting to the no command screen and then messing with he android menu and factory restoring it. But know it don't like to keep her apps on the screen. So trying to be a smarty pants I stuck them all in a folder on the home screen and restarted it to see what it did. Well when it came back on the folder was empty, when I clicked on the blank folder it said launchpad failed and then it blinked for a second and not only did the apps return in the folder but so did her original ones that was on her home screen.
Well when I called tech support for all of this I got the usual run around and they tried to get me to do another factory reset and this and that and I almost had them just send her a new one until they asked me for the receipt of the original so they can confirm when I bought it. Well at this time I think it got tossed on accident buy are roommate because we keep tech receipts know nextbook wont do anything cause I cant show proof of when i bought it. So is there anyway to convert it back to the firmware it had on it that actually worked? Or shoudl I try and just re-run the update on it? -
Check this out. Will fix it. Will root though. http://forum.xda-developers.com/show....php?t=2762092
[Root] Nextbook 8 Quad Core NX785QC8G
Originally posted by infirno77 View PostCheck this out. Will fix it. Will root though. http://forum.xda-developers.com/show....php?t=2762092
Re: Nextbook8 NX785QC8G problems that tech support wont help me with.
Originally posted by kyuketzu View PostI have never done anything like that before and I am wondering if there is a ROM of the original firmware out there.
ShaunMT's Modified ROM for Nextbook NX785QC8G (Support Thread)
But it is rooted.
Originally posted by kyuketzu View PostIs there a way to back up her firmware before I do it?
Originally posted by infirno77 View PostThen go to the next booked website and download the latest firm ware again. You may have had a bad download
Originally posted by kyuketzu View PostWell I installed ShaunMT's rom to the tablet and I am still having a problem with it not keeping the icons on the screen and if they are in a folder it says Launcher3 stopped working and then I hit ok and the screen flashes and then all the stuff reappears. Should I do a factory install?
There are currently 2336 users online. 0 members and 2336 guests.
