First post. I'm French so my english will not be perfect, sorry
I have a Tomato-like square M8 with the right pcb and Samsung RAMs. So everything is okay for now and i'm using right now Finless 1.8 which is great.
I noticed while playing the cpu consuming Riptide 2 a lot of freezings.
That said, while playing, the box becomes very hot and then suddenly, freezes to death. I have to disconnect and connect back the power jack to get it to work again.
It happens very easily with Riptide 2, because this game uses all the 8 cores of the Mali 450 to substain a good framerate, even in 1080p, and all the 4 cpu cores to display video effects and so on.
We could say that's the perfect stress test for the square M8 and its tiny heatsink radiator.
I noticed with the original firmware that i could play around 10/15 minutes before the hangons.
Then with Finless its more about 10 minutes max. Why that ? Because Finless gives us more power than the original firmware. Even the original launcher is faster in Finless !! Antutu score is better. 3D GPU Bench is better as well in Finless than with the original firmware.
So, what are we dealing with ? very good firmware with Finless, very good computing power, but a lot of heat that the original heatsink cannot substain, that's all !
So, i have a sollution for you. With this, i ran Riptide 2 for 2 hours without a problem !!
Pictures in next post
Best regards,
Philippe
