Overheating !
Originally posted by SSThing View PostWhere did you take the 5v supply from to the fan?Minix Neo X7 - Wasser 1.0.4 OC'd - Kodi-helix with passthrough
Beelink M8B - Wasser 1.0.3 - Kodi-helix alpha 2 + SPMC
i followed this guide using a 12cm case fan that my m8 box sits on it works very well http://www.freaktab.com/showthread.p...Android-TV-box ,turn the box off and the fan stops.
And maybe you should use a Y-cable (extension cord) like this
http://www.****.de/itm/140750429441?...%3AMEBIDX%3AIT
to use the USB-port also for other things...RK3288 Devices
- Overview BOX (LINK !)
Well, so far so good.
Decided to add another full-size fan onto the bottom as suggested a couple of posts earlier, now I know its as easy as cutting up an old usb lead and soldering the wires to the fan I thought I may aswell. Both fans are 12v but are running perfectly well on 5v, albeit no doubt slower. Box is running very cool and so far no lockups or reboots. I imagine that the exterior fan option would be enough (I would still take out the metal plate/ballast so that the fan can draw the heat all the way through the box), but I am not going to bother taking out the internal fan.
Found this also!!
http://www.****.co.uk/itm/M18-Portab...item3f3d212314
I am sure a modified case will accomodate this with all the silicon adapters supplied.Last edited by jeffben; 19 September 2014, 16:33.
well dont i feel like a fool, ive spent days on end trying to figure out why my m8 kept locking up... id reconfigured xbmc nearly 100 times thinking it must be some rogue addon causing the lockups! then I happened across this thread... opened up the box and sure enough one of the plastic legs holding the heatsink down had broken and the poor unit had been overheating this whole time!
Thank you to the OP and all the others, im going to add the noctura low noise fan, I had in my parts drawer.
Has anyone else done any cooling mods to these units?? if so please do post pics / details
There are currently 2806 users online. 0 members and 2806 guests.
