About location value in RKDevelopTool_v1.37 I am not sure if it has to be changed. If somebody knows, please tell us how.
Any Luck Overclocking CS968 with MTK Chipset?
Originally posted by Dzigi.Bau View PostI found out that my device is v5 one. Perhaps D33's kernels work on v4 and other. If anybody could confirm that D33's kernel work or not on CS968 MTK v5, or give us direction what to do to make it work.
I am also trying on my version 5 box my other unit is a V3. I don't think these kernels work on either of my units. I will retry my V3 which id running the QuickShot Rom. The location in RK tool is set to 4000 in my copy so it does seem to be what Frant suggested.
Perhaps Frant could offer us some more assistance since he seems to have been successful with his combo.
EDIT My V3 with QuickShot boots fine with MTK overclock kernel ....still no WIFI /Bt
Originally posted by Dzigi.Bau View PostThat means Kernels from here http://www.freaktab.com/showthread.p...8well-most!%29 do not work on CS968 MTK v5 devices. Perhaps, somebody could tell that to D33, if he has a time to create one working on our devices.
I am not sure about V5 boards. Frant indicated that his was working with V5 (post #9). Have you tried the QuickShot Rom? If it works on your box try installing the kernel that Frant indicated. That will help us eliminate if it is a V5 problem or a Rom/Kernel issue.
Thanks.
EDIT: I installed QuickShot Rom it worked as expected. I then installed the HD KK kernel that worked on my V3.......BOOT LOOP!!!!!
So it looks like V5 is different enough to not function properly with the current OC kernels.
I may try my V3 with a stock Rom and try the same Kernel to see if it works there.....Last edited by quincydog; 12 September 2014, 14:55.
Thanks.
well i have a cs968 v5 (mt5931 rk3188T etc...) and i have build a D33 kernel, with some changes and now i can boot
I have build 2, 1 normal kernel cpu/gpu/ddr stock FULL HD and the other overclocked (took me some time to find a perfect combination that work on my device) cpu 1600/gpu 600/ddr stock FULL HD.
The only thing that wont work its the damn camera, i dont know what module to build.....
Everything else works good, Ethernet wifi and bluetooth.
Tested on a Tech1 rom, "CS968_2MPZX19.2-MTK-T018-UltraPlus-Android TV-Multi-Media-Super-ROM-20151231_update.img"
Thks to D33 for its kernel, and tech1 for its rom.
If anyone want to test at your won risk i can upload the kernels...
Some Screenshots, some from "normal" kernel(lower score) and other from "OC" kernel(bigger score).Last edited by superceleron; 29 September 2014, 03:05.
Originally posted by superceleron View Postwell i have a cs968 v5 (mt5931 rk3188T etc...) and i have build a D33 kernel, with some changes and now i can boot
I would be interested in trying your various combinations. Perhaps if they work for a few of us they could be pinned as a usable way to get full 1080 and overclock for our MTK versions.
Thanks for your response. I have hope!!!
Quincydog
Here you go, leave feedback if it works or not.
Camera wont work.......
PS: after update the kernel go to screen settings and change resolution again, its not needed but its hallways good to reset the setting.Last edited by superceleron; 01 October 2014, 21:36.
Originally posted by superceleron View PostHere you go, leave feedback if it works or not.
Or was it just DDR overclocking you turned off?Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by d33 View PostHi. Great to hear that you have re-used my work! Could I ask a little favour? Could you tell me what changes you made to get this particular model working? I will include into the current source, with acknowledgement as you as the source of the fix.
Nop its not only the ddr, disabled all that was normal RK3188(OC of course) and for the RK3188T the CONFIG_RK3188T_CPU_OVERRIDE was the only option that i enabled and CONFIG_RK_PWM_VOLT_MAX_1450 and disabled the DDR oc.(my device uses elpida...)
Still cant make the damm camera work lol.
If you want my .config i upload it.
Originally posted by superceleron View PostNop its not only the ddr, disabled all that was normal RK3188(OC of course) and for the RK3188T the CONFIG_RK3188T_CPU_OVERRIDE was the only option that i enabled and CONFIG_RK_PWM_VOLT_MAX_1450 and disabled the DDR oc.(my device uses elpida...)
If you want my .config i upload it.Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
I will try these in the next couple of days.
Originally posted by superceleron View PostBtw D33 do you have any idea why camera wont work? its 2mpix camera.
I have the dmesg of your kernel and from my original kernel, if you can have a look.
Regards.
Using my ipad so apols for any stupid ios spelling 'corrections'Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
There are currently 2310 users online. 1 members and 2309 guests.
