The Upcoming Talk U55GT-8c/ Talk 79 Octacore
Re: The Upcoming Talk U55GT-8c/ Talk 79 Octacore
I like the look of this myself. Will be keeping an eye out for cube making the firmware available for download and will take a look at reworking the ROM.900Supersport
freaktab developer
If it will be good/stable as the talk 9x, will be a best buy in this size!if you appreciate my efforts this is the link for any donation:
Not heard from them yet, we'll see.900Supersport
freaktab developer
put the following .zip file on a microSD card (do not extract it!)
insert the microSD in the tablet
update.zip
switch on the tablet normally:
go on settings->system updates
follow on screen instructions
that's all.if you appreciate my efforts this is the link for any donation:
[QUOTE=giouncino;235540]put the following .zip file on a microSD card (do not extract it!)
update.zip
that's all
Thanks but doesn't work. recovery says update is for u65gt not u55gt-8c
I supposed it could work because of the same brand and same SoC between your tablet and cube talk 9x....
Probably with some simple modifications of the files in the zip you can use it on your tablet...if you appreciate my efforts this is the link for any donation:
Originally posted by rfgod3 View Postmy cube talk 79 u55gt-8c arrived today verry impressed!
Does any one know how to root it?
thanks
Getting this tablet next week
Hi guys.. I'm new to this forum as this is my first post. I'm planning to get this tablet next week because i kinda like the specs and size. Has anyone succeeded in rooting the device? . Can the recovery that came with the device do a full nandroid backup or is another cwm based recovery required. Thanks in advance for your replies
There are currently 2972 users online. 1 members and 2971 guests.
