Maybe it'll work for you like it does for me. Try it and good luck!
Custom ROM - Bluetimes QPRO/MK902II/CS918II/CX998/CS968/Cloudnetgo CR12/13/16
Originally posted by yric37 View PostThere is not a switch "on" and "off" debugging mode in setting. How to flash?
Originally posted by yric37 View PostHi, Shamori. One issue with screenshot. I received only black screen in a resault of making screenshot.
Originally posted by yric37 View PostThank you. One issue else. Remote power button do not power off, only sleep. If device is shutdown you can not to power on it by remote button.
Did this issue start happening with the latest update or was it in the first rom too?
Originally posted by Shomari View Post'Special', not so much. But there is one that I prefer, it's the Kodi test build (not nightly) from 09/01/14.
With you rom, I can play DTS with the native video player. But KODI doesn't even tries.
What are your settings in KODI and the system?- HDMI bitstream?
- which kodi HW acceleration settings?
- which display settings?
Originally posted by Finless View PostJust some advise....
Relax and try to ignore those that upset you.
This place is in many ways my last refuge of late so I thank you for maintaining these forums where we can all help each other and take part in a hobby that helps some of us (at least me) escape all the other strife that comes with life.
Originally posted by strikegun View PostThank for the hint, but I already using the alpha3 of kodi.
Thank you for posting this, because my hope is someone with an equipment setup similar to yours may be able to help more than I can once they read it.
My setup is just HDMI video to TV, and SPDIF over optical to a very basic receiver.
Can you please try to play a 3d movie in the default RKVideo player and then grab the dmesg for me to see what the system is doing while it plays? I may be able to pinpoint the problem and better yet hopefully a solution.
At this point based off what you're saying I'm still unsure if it's a ROM issue or an issue with Kodi.
If the issues are with Kodi take a look at this page and make sure you have met the basic requirements for 3D playback, particularly the part about ARM and android limitations http://wiki.xbmc.org/index.php?title=3D
Originally posted by scooter2014 View PostAwsome ill download and test out this weekend. This is my birthday pressy as Girl friend is allowing me to play with my toys all weekend
Thanks for making it a great weekend. Ill have 5 or students here playing with it as well so let me know anything you want tested lol....
Originally posted by Shomari View PostMine works fine with the remote, I set it how I like it, to go to sleep and then resume with the remote. Maybe this is one of those issues between devices even though they use the same board?
Is this issue start happening with the latest update or was it in the first rom too?
Originally posted by yric37 View PostYes, this issue start happening with the latest update. After update on Measy display power button gives only shutdown, not to choose, while on remote - only to sleep. After power off by display button you can not power on by remote.
But you can put the device to sleep and resume normally with the remote, yes?
I'll try to add the sleep option to the soft power button in the navbar in a future release.
Originally posted by Shomari View Post..aaah. I see. the power button in the system bar shuts the device down, and you'd like an option to put it to sleep.
O.K. I shall wait for next release. I like your ROM.
Remote power button must power on and off. It did only to sleep and nothing else.Last edited by yric37; 20 September 2014, 11:09.
Originally posted by yric37 View PostNo, I can not put the device to sleep and resume normally with the remote, only sleep not resume.
I'll see what I can figure out, it makes me wonder if this is kind of the little issues that come up between different devices. Thanks again for your feedback, I appreciate it.
Originally posted by Shomari View PostIf the issues are with Kodi take a look at this page and make sure you have met the basic requirements for 3D playback, particularly the part about ARM and android limitations http://wiki.xbmc.org/index.php?title=3D
My problem is the 3D Bluray Isos or MKV as MVC. Or is 3D Bluray not supportet by RK3288?
Can you explain me short, where I get the dmesg results? is there a app or a terminal ?
There are currently 1513 users online. 1 members and 1512 guests.
