Custom ROM - Bluetimes QPRO/MK902II/CS918II/CX998/CS968/Cloudnetgo CR12/13/16
Originally posted by Shomari View PostHaven't looked at the linked ones but the one copied here shows the audio is being muted. So you didn't get audio when you tried playback?
My Audio is running, only not in the type it is in the stream. DTS-HD Master not getting passthrough.
Only 5.1 DTS is coming.
Under Settings->Display switching on HDMI Mode to Auto, I get 720p/60. Only manual selection of higher resolution, I get the correct ones.
I think the HDMI EDID detection don't work correct.
Originally posted by strikegun View Postthink that wasn't me. I only posted the links.
But, I do have a test build that uses a non-default audio config you can try. It'll be a couple days but I'll try to post it for you.
Hi to all, I can confirm that Shomari rom works also on Cloudnet CR13/FITO BMD4000.
EKB328 and Q8 have the same rom. Both stock roms have a problem with the ethernet, but on your rom ethernet works great...
Shomari can you point me in the right direction so I can make the remotes work on EKB328/CX-998/B368 ? I have the dumps of thier stock roms do they help ?
Originally posted by mindful View PostHi to all, I can confirm that Shomari rom works also on Cloudnet CR13/FITO BMD4000.
And I can't believe how many stock ROMs are still coming with broken ethernet.
Originally posted by mindful View PostI think i broke my EKB328...
I accidently selected the boot file RK3288Loader_uboot_V2.15.bin also ... and pressed Run .... now AndroidTool has stopped at:
Test Device Start
Test Device(100%)...
Tryed reseting it ... no luck ...
....you're fine. just have to select your parameter files/loader and the rest as if you're flashing a full ROM
I tryed that allready ... anything i do it says the same thing:
Test Device Start
and it stops here...
Regarding the remote control ... I copied the hole keylayouts folder from q8 to your rom and the remote is still not working ... the remote from the qpro works with the q8
Originally posted by yric37 View PostNo, I can not put the device to sleep and resume normally with the remote, only sleep not resume.
O.K. I shall wait for next release. I like your ROM.
Remote power button must power on and off. It did only to sleep and nothing else.
Hope that helps.
Measy B4S
Originally posted by jeffben View PostHi I found that to Resume after going into Standby you need to press the power button on the Remote for more than 10 secs. Also found this an issue on the Tronsmart R28 RK388 box running KK and use the same method.
Hope that helps.
Hope that helps.
On the QPRO standby/resume function normally, without long press.
For a later release I'm going to work on incorporating proper IR remote compatibility across devices.
hello all, first post, gotta say quick thanks to you all for helping me resurecting my 3066 stick from the dead, works a treat now with the 4.4.2 rom and a heatsink.
anyways, i just got a sunchip cx-998l from ****, and have begun tweaking it, managed to debloat it alot but am interested in this rom as the last rom shomari posted is working really well on the 3066. Couple of quick questions:
:-) 1. it was mentioned that the ethernet is not working on the cx-998 with this rom, I prefer to use it on my box, is there anyway to merge files/drivers from the stock rom?
2. I have noticed that my stock rom is not smooth at decoding most video, not as smooth as the 3066 stick on 4.4.2. There is noticable stutter when using both hw and hw+ decoding in all media players, do you guys have this too? any ideas what my be the issue?
anyway, thanks in advance for all the development you guys have done to make these devices much more useable.
RK3288 Devices
- Overview BOX (LINK !)
There are currently 2971 users online. 0 members and 2971 guests.
