ndk r9c
platform 17
openssl 1.0.2 beta
libiconv 1.1.4
ffmpeg 2.3
#define DVB_API_VERSION 5
#define DVB_API_VERSION_MINOR 10
support transcode stream (may be work with vpu of rk3288)
your device must be root
copy data to data
copy sytem to system
if you have your rom support init.d. reboot your device
or
open terminal
write
su
mkdir /dev/dvb
mkdir /data/data/.hts
mkdir /data/data/.hts/imagecache
mkdir /dev/dvb/adapter0
ln -s /dev/dvb0.frontend0 /dev/dvb/adapter0/frontend0
ln -s /dev/dvb0.demux0 /dev/dvb/adapter0/demux0
ln -s /dev/dvb0.dvr0 /dev/dvb/adapter0/dvr0
ln -s /dev/dvb0.dvr0 /dev/dvb/adapter0/dvr0.ts
ln -s /dev/dvb0/ca0 /dev/dvb/adapter0/ca0
mkdir /dev/dvb/adapter1
ln -s /dev/dvb1.frontend0 /dev/dvb/adapter1/frontend0
ln -s /dev/dvb1.demux0 /dev/dvb/adapter1/demux0
ln -s /dev/dvb1.dvr0 /dev/dvb/adapter1/dvr0
ln -s /dev/dvb1.dvr0 /dev/dvb/adapter1/dvr0.ts
ln -s /dev/dvb1/ca0 /dev/dvb/adapter1/ca0
chmod 777 /data/data/.hts
chmod 777 /data/data/.hts/imagecache
chmod 777 /data/dvb*
chmod 777 /data/dvb/tvheadend
./data/dvb/tvheadend -C -c /data/data/.hts
later open browser write url
127.0.0.1:9981
if you look setup screen that is work
other hand if you have dvb-t-s stick need driver modules. modified init.d script line 7-12 (may be add new line needed modules)
for example
insmod /system/lib/modules/xxxxxxx.ko
insmod /system/lib/modules/xxxxxxxxx.ko
insmod /system/lib/modules/xxxxxx.ko
insmod /system/lib/modules/xxxxxxxxxx.ko
if I learn to compilie kernel of rk3288. I make
Files
