It is similar/the same as the http://www.geniatech.com/pa/pt115m.asp and http://mygica.com/html/TV_Tuner/20140802/16.html
The program used to view live TV is the same for all of them https://play.google.com/store/apps/d...ad.tvapp&hl=en
The program is ok and does work, but nowhere near as good as Kodi and TVHeadend.
Extracting the APK results in a /lib/x86 and lib/armeabi folder, both containing libPT917xDrv.so, lbPT913xDrv.so, libPadTv_ini.so, libPadTVdatabasejni.so, libDVBCodec.so and libA681xDrv.so.
TVHeadend still doesn't detect any DVB-T devices after installing the APK.
Dmesg doesn't show any drivers being loaded, but the Pad TV HD app plays live TV without problems.
The device is shown as idVendor=1f4d, idProduct=a115, Product: USB Device and Manufacturer: Geniatech.
Is there any way of using these .so/library files for TVHeadend?
