remote.conf for square remote (v1 m8)
    Afternoon,
    As the title suggests, does anyone have the remote.conf for the square remote that comes with the v1 m8 square units?
    tyvm
    Finally signed up with an account, always lurking; never posting
    Hi
    I have it.
    You can save the text bellow in a remote.conf text file :
    #this file is configuration for each factory remote device
    # work_mode 0 :software mode 1 :hardware mode
    # repeat_enable 0 :disable repeat 1 :enable repeat
    # factory_code each device has it's unique factory code.
    # pattern:custom_code(16bit)+index_code(16bit)
    # examble: 0xff000001 = 0xff00(custom cod) 0001 (index)
    # release_delay unit:ms.release will report from kernel to user layer after this period of time
    # from press or repeat triggered.
    # debug_enable 0 :debug disable 1 :debug disable
    # SW MODE:
    # bit_count how many bits in each frame
    # tw_leader_act time window for leader active
    # tw_bit0 time window for bit0 time.
    # tw_bit1 time window for bit1 time
    # tw_repeat_leader time window for repeat leader
    # REG
    # reg_base_gen set value for PREG_IR_DEC_BASE_GEN
    # reg_control set value for PREG_IR_DEC_CONTROL
    # reg_leader_act set value for PREG_IR_DEC_LEADER_ACTIVE
    # reg_leader_idle set value for PREG_IR_DEC_LEADER_IDLE
    # reg_repeat_leader set value for PREG_IR_DEC_REPEAT_IDLE
    # reg_bit0_time set value for PREG_IR_DEC_BIT0_TIME
    #amlogic NEC remote
    factory_code = 0xfe010001
    work_mode = 0
    repeat_enable = 1
    repeat_delay = 40
    repeat_peroid = 39
    release_delay = 121
    debug_enable = 1
    fn_key_scancode = 0x00
    left_key_scancode = 0x51
    right_key_scancode = 0x50
    up_key_scancode = 0x16
    down_key_scancode = 0x1a
    ok_key_scancode = 0x13
    pageup_key_scancode = 0x55
    pagedown_key_scancode = 0x54
    mouse_begin
    0 0x51
    1 0x50
    2 0x16
    3 0x1a
    mouse_end
    key_begin
    0x01 11
    0x4e 2
    0x0d 3
    0x0c 4
    0x4a 5
    0x09 6
    0x08 7
    0x46 8
    0x05 9
    0x04 10
    0x13 97
    0x19 15
    0x42 14
    0x16 103
    0x1a 108
    0x51 105
    0x50 106
    0x11 104
    0x18 102
    0x10 125
    0x4c 109
    0x5a 119
    0x59 122
    0x52 128
    0x58 123
    0x54 120
    0x55 121
    0x40 116
    0x41 113
    0x45 130
    0x49 134
    0x0a 133
    0x48 138
    0x4d 70
    0x0e 136
    0x0f 135
    0x43 132
    0x03 127
    0x06 139
    0x44 140
    0x00 63
    key_end
    repeat_key_begin
    0x01 11
    0x4e 2
    0x0d 3
    0x0c 4
    0x4a 5
    0x09 6
    0x08 7
    0x46 8
    0x05 9
    0x04 10
    0x13 97
    0x19 15
    0x42 14
    0x16 103
    0x1a 108
    0x51 105
    0x50 106
    0x11 104
    0x18 102
    0x10 125
    0x4c 109
    0x5a 119
    0x59 122
    0x52 128
    0x58 123
    0x54 120
    0x55 121
    0x40 116
    0x41 113
    0x45 130
    0x49 134
    0x0a 133
    0x48 138
    0x4d 70
    0x0e 136
    0x0f 135
    0x43 132
    0x03 127
    0x06 139
    0x44 140
    0x00 63
    repeat_key_end
      How do I use this file?
      where to place?
      How to make sure it is read?
