Changelog:
1. Partially deodex.
2. ROOT by default Superuser app from Clockworkmod. Thanks Brian for the idea.
3. Remove all applications in Chinese.
4. By default, the English language at the first boot
5. Modified boot.img:
a) real support init.d, enough to put the script in init.d folder and enjoy the implementation of the script;
b) Permissive mode by default, USB OTG NTFS support ;
c) checkbox is checked USB debugging at first boot, then you can disable it.
d) full ADB shell for those who understand;
6. Reduced the minimum display brightness to a lower limit and a bit downgraded Auto Brightness level.
7. Implemented system application Font Chooser in Settings \ Display to change the fonts.
Now the choice of 30 possible. Development hartec. Thank you so much.
8. Modified file platform.xml for full access to the memory cards. Thanks Brian for the idea.
9. Implemented library libMali.so for Chrome. Thanks to dmc0306.
10. Introduced gps.conf file in my wording to help the GPS on the territory of Russia. If you do not fit, delete it or edit (\ system \ etc)
11. Removed from the Settings \ On-line update and tablet Wireless Update. They do not make sense in my firmware modifications.
Updates, if any, are placed only through modrecovery CWM or TWRP.
12. Reduced the critical threshold of the battery discharge to 10%
13. Apply white theme if possible.
14. Slightly changed the default wallpaper to the antenna icon blue color was visible.
15. repainted battery icon in the status bar, make the clock in the middle.
16. Statistics battery is kept after a reboot.
17. Implemented stock flashlight. Works without pre-flash.
18. In the folder \ system \ etc \ init.d \ script is 98_media. Theoretically, it should solve the problem of the media server and kill some media processes. If you do not need, delete without regret.
19. preinstalled:
a) Titanium Backup
b) MobileUncle Tools
a) CpuSpy
g) WakeLock Detector
d) RootExplorer (in the program settings to choose a theme and Light is in the general style).
Screenshots can be seen in the message below and here.
Installation Instructions:
Only for installation through modrecovery CWM or TWRP!
Archive firmware to put in the root of the internal or external memory (can be in any directory with the Latin name). Boot into recovery. Make a backup of the current mandatory firmware better on an external memory card. Then make the necessary wipes tab ADVANCED:
1 Dalvik Cache
2 System
3 Cache
4 Data
5 Android Secure
Then select Install (TWRP), specify the path to the file to confirm the firmware and swipe process of firmware. Wait for a successful finish and boot the system. Make settings by yourself.
Sorry for my bad english.
Download
U65GT_V1.8.4_20140930W_en_mod_Lepi.zip
MD5: 061697a68c91607e327d5ced3a862b55
There are no guarantees! Risk and assumes responsibility fully by the user.
Preliminary backup is required!
Successful upgrade!
