U65GT_V1.8.4_20140930W_en_mod_Lepi
Originally posted by gurzo82 View PostHi, thanks for your work, but link in the first page to download the rom doesn't work anyomre...con you provide another one?Thanks
Video Tutorials
Originally posted by yungwizzy View Posthow do i flash ur mod twrp on my tab?? am a newbie on android
https://yadi.sk/d/S_P03itXXyWEv
https://yadi.sk/i/Qs4ewCc8XyWTb
https://yadi.sk/i/ABm4gGcCXyWWN
https://yadi.sk/d/_qkzVHXfY7LWK
Re: U65GT_V1.8.4_20140930W_en_mod_Lepi
NEW! TWRP 2.8.1.0
Offer your attention a new recovery TWRP 2.8.1.0. Author SevenMaxs from 4PDA. It`s my port with new light Theme.
ChangeLog:
- Mount the two flash drives - internal and removable SDcard Emmc PC
- USB-flash drives work with file systems or Fat32 exFat
(you connect the USB flash drive to the phone on Otg-cable and Mount tab put a tick against the item on the Usb-Otg)
- Choice of FS (ext2, ext3, ext4, f2fs, exfat, fat32) for the formatted partition ..
- Working USB-mice
- Separate checkbox to restore rekaveri
- Full functional adb
- Displays the battery (by connecting the cable + symbol appears near percentage of battery)
- Apply the light theme from ScumpinatoS
My patch for modrecovery (CWM or TWRP)
TWRP_2810_LEPI_light.zip
Install from modrecovery! No guarantees! Preliminary backup required!
To install via Flashtool need to extract from the archive file recovery.img, put in a folder with a scatter (folder name in Latin letters only!) and flash it.
Successful upgrade!
Do not restore backups from previous versions of 2.7.0.0! Sorry.
Originally posted by Freewaymad View PostHi,
I installed the new TWRP 2810 using the old TWRP 2700 with no problems. It works as expected, awesome. The new settings are very nice to have. Thanks and as always keep up the great work.
best
Originally posted by Lepi View PostOffer your attention a new recovery TWRP 2.8.1.0. Author SevenMaxs from 4PDA. It`s my port with new light Theme.
ChangeLog:
- Working USB-mice
Successful upgrade!
i like this twrp but i used to work with cwm.i hope one day cwm also looks and work like this.
all the best
Originally posted by priyanga View Posti like this twrp but i used to work with cwm.i hope one day cwm also looks and work like this.
Originally posted by ammo2003 View PostGreat job Lepi, but does this ROM support NTFS flashdrives on OTG? Keep it up !
b) Permissive mode by default, USB OTG NTFS support ;
There are currently 2121 users online. 1 members and 2120 guests.
